08-27-2018, 05:23 PM | #1 |
Speedo pulse generator speed sensor?
Trying to find a speed signal generator for my th350 with Dolphin electric speedo. Surprisingly elusive. Suggestions welcomed!
1951 Chevy Panel Truck |
08-27-2018, 05:42 PM | #2 |
Re: Speedo pulse generator speed sensor?
Reed type or sine wave? Pulses per revolution?
08-27-2018, 08:39 PM | #3 |
Something of this nature?
https://www.summitracing.com/parts/i...SABEgId2fD_BwE
08-28-2018, 07:44 AM | #4 |
I can't seem to find any instructions or specs, and it looks like there are several different models of gauges to choose from. There are a number of different types and models of sensor available. Two or three wires to the sensor can be used to determine sine wave vs reed type, but output voltage probably needs to come from specs. Number of pulses per revolution is also critical but without specs it will take a signal generator to work it out. Speed sensors are available from many different sources. Years ago I used United Speedometer in Riverside CA but it look like they're not the best choice anymore. The one linked from Summit may work but then again...
08-28-2018, 08:03 AM | #5 |
I’m not sure about Dolphin, but my speedo can be programmed from 4000-200,000 pulse per mile, 16,000 being the standard.
More info on your specific gauge will help. May also consider the pulse generator offered by dolphin https://www.dolphingauges.com/produc...ulse-generator
08-29-2018, 03:56 AM | #6 |
Dolphin sells a GM pulse generator, so I ordered that. I didn't think it would work because my speedo has a 1-wire hookup to the sensor, but the sender has 2 wires. They said just hook either wire to the speedo and the other to ground.
Really the only reason I need a speedo is to fill the hole in the dash. The new cell phone speedometer apps are free and they look cool too. I used DigiHud on my last hot rod.
