![]() Join Date: Aug 2004
Rebirth of Clyde
Starting to document the transformation of my truck. I have had Clyde since 1989, I got him road ready and started to drive him. Sorry no pictures of the beginning.
These are the things that I have done to my truck prior to build thread. Rebuilt front suspension 2.5” CPP drop spindles 2” drop springs 72 front sway bar Shock relocators KYB shocks Rebuilt rear suspension Rebuilt 12 bolt 3.73:1 gears Eaton Posi Relocated fuel tank Boyd’s 63-72 c10 19 Gal tank American Racing radiator 2005 4.8l fi motor 2002 4l60e trans Tune by: Nelson Performance Harness by: Clinebarger
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 04-28-2019 at 04:26 PM. |
Re: Rebirth of Clyde
Here is Clyde in 2002, high pockets and all.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 09-06-2018 at 10:27 AM. |
Bed rebuild. 2016
New wood, stained like MAR-K has on their site. 67-72 C10 Sport Bumper also
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 09-06-2018 at 10:28 AM. |
Tear down for paint
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
and the dirty work begins
also added the center AC vent and side vents from Corvette Jim
Clyde, is Looking Pretty Sharp!
Added some bling to Clyde today
Very nice.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
New front springs, rear bumper on and a ball joint replacement.
Looks better than ever!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Wow. Got a lot done over the fall months
Clean Machine!
Wow!
I'm not really a lowered truck fan, but your's looks really good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
#15 |
Thank You sir!
#16 |
Got the grill disasembled, parts sent for powder coating. I cleaned and sprayed new color on the letters, look pretty good.
#17 |
![]() ![]() ![]() Join Date: Jan 2018
Hey Clyde, that grille looks beautiful! Also love the rest of the truck.
I have a question if you don't mind answering about the rear suspension setup you have. I have seen your other posts about the truck bed trailer you have and the sweet camper as well, and I was wondering how the truck handled it with being lowered. I want to lower mine some, but still want to be able to tow a truck bed trailer and my dad's Champion bass boat. Thanks in advance!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#18 |
That grill looks amazing!! As well as the rest of the truck.
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
#19 |
Thanks kdad, can you believe it’s 20 years old?
#20 | |
I haven’t driven Clyde and Bonnie( the Camper) together much, I put air bags on Clyde to handle the weight and be lowered. I had 4” drop springs and they were way to soft, almost dragging the ground. With the airbags, I just air them up to (45# driving) whatever is needed to handle the extra weight. It really depends on how much you want to lower it. 2” wont hurt you at all.
#21 | |
I really like the grille and the fresh powder coated parts. Did you use new screws for the bulb retainer rings? I'm missing some screws, and I have no idea where to get some from
#22 | |
#23 |
Thanks! I'll check them out
#24 |
Got powder coating back and assembled some stuff. Found out my old HID’s had a crack in one so, getting new ones, no LED
#25 |
Looking good !
http://67-72chevytrucks.com/vboard/s...d.php?t=765151 |
