09-17-2018, 09:28 AM | #1 |
Oh,you can't buy that new
VORTEC OIL PAN from a 99 burb fit my 81 GMC?
I am rebuilding a 99, 5.7L roller vortec 'R' engine for my 81. I like the oil pan and windage tray on the vortec engine. will this stock suburban oil pan fit the square? thanx, Crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
09-17-2018, 11:06 AM | #2 |
Re: VORTEC OIL PAN from a 99 burb fit my 81 GMC?
Blocks should be the same, I would measure the pan and check to make sure the dip stick is in the same location (should be).
Double check just to make sure no one put in an older block from pre 79. 55-79 was different, but 80-99 (or whenever they changed block) should all be the same Oil pan.
09-17-2018, 08:21 PM | #3 |
If you are wanting to know if the oil pan will fit the chassis and clear the crossmember and what not, yes, it will.
The '99 L31 oil pan will not fit the '81 block. |
09-17-2018, 08:52 PM | #4 |
i just set a brand new l31 vortec in my 1980's k30 truck no problems . its 4x4 . not sure if your doing 2wd or 4wd .
and i got my brand new l31 long block for just under 1800.00 delivered . not sure what your spending on a rebuild .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-19-2018, 09:32 AM | #5 | |
My engine was a 100% complete L31, and I noticed that oil pan in center had more of a taper than drop step like 81 pan had. but my ? is answered ,and I will proceed. I wanted to run the 99 pan because it has a small windage tray inside I want to retain, and also I can just keep buying 99 engine parts :-) - thanks guys
09-17-2018, 08:52 PM | #6 |
driving is in my blood
Your answer is yes.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
