10-07-2018, 06:45 PM | #1 |
is power steering cooler necessary?
Using 5.3l L59. I will not be towing or racing the truck, just recreational cruising. Is a power steering cooler needed?
10-07-2018, 07:55 PM | #2 |
Re: is power steering cooler necessary?
When i got my lq9 it came with a cooler...so i used it...but im running hydroboost so im guessing thats why the cooler...
10-08-2018, 07:54 AM | #3 | |
Towing or straight line racing will not really affect it . Its the constant turning back and forth that will heat the fluid . Last edited by homemade87; 10-09-2018 at 07:26 AM. |
10-09-2018, 08:04 AM | #4 |
Ive never used one either. Just a DD and no problems.
10-09-2018, 11:39 AM | #5 |
GM has coolers on there because of the inefficient design of the pump, not because of anything else. The type p-pump (ham can the trucks use) has a ton of bypass which heats up the fluid too much, making the cooler a necessity. The overassist also robs HP as well.
I converted to a type II pump which made it a much more efficient and better feeling (steering, not emotional) setup.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
10-09-2018, 02:02 PM | #6 |
Thanks for the responses. I am not running the stock PS pump. I am using a Holley pump. I will look into the holley pump requirements.
10-09-2018, 02:07 PM | #7 |
I didn't know holley had a pump but its likely based on the type II design and most likely will not need a cooler. If you are going to autocross or track day it, it'd be a good addition but not really necessary for the street.
10-13-2018, 09:07 AM | #8 |
Nope i dont have one lol
10-13-2018, 05:31 PM | #9 |
Adding a PS cooler is not a bad idea to tell the truth. On cars with LS engines like Camaros and Firebirds I've seen where the fluid actually boils out of the reservoir. I haven't added one to mine but I should. It has gotten close to that point. Flushing burned fluid in not a bad idea either.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
