Who Me?
AC/Heater control switch issue
I only have air coming out at the defroster. I can move the switch from position to position and the air flow doesn't change. When I move the switch from the different settings, it make a positive stop at the floor position. The others it seems to glide on past.
Is this an issue with the switch? Is it something that is replaceable instead of replacing the entire control panel? Thanks for your help! Steve
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Moderator
![]() Join Date: Oct 2008
Re: AC/Heater control switch issue
Year?
AC or No?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Who Me?
97 with ac
It's probably the motor that controls the vent selection. It's above the gas pedal and is pretty easy to replace. Check the linkage up in there too, it might be loose.
Mike |
Who Me?
Who Me?
So I removed this motor and left it plugged in while changing the switch. There was no movement when I changed the switch positions. I can manually move the blend door from position to position easily.
So is this motor or the dash switch more likely to fail? Thanks again for the help guys!
Moderator
I've had theMode Door motor and a blown transistor on the dash controller do this. If the motor isn't turning it could be either...
Usually the motor isn't the issue with actuator failure... it's stripped internal gears. Been there done that on several GM vehicles. If you dig around in the 98 service manuals there's likely a test procedure. The Mode Door motor is less expensive to replace but it's still $20-$30. But I'd lean toward the dash switch module. The last one I replaced was $100 or a little more from GM. The Mode Actuator or Motor controls the air flow door or flap... Floor thru Defrost. The Mode Actuator is on the driver side of the HVAC box near the accelerator pedal. The Blend Actuator or Motor controls the temperature door/flap. The Recirculation Actuator or Motor controls the Recirc or Fresh Air door/flap that routes air from outside or inside the cab to the HVAC box. I believe Blend and Mode motors are the same part on the GMT400 after 95 or 96.
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-17-2018 at 02:41 PM. |
Who Me?
The little bit of testing I did was looking for voltage at each of the 3 wires when changing the mode. I only had power one the black wires as I changed modes. I also heard nothing when I removed this one near the gas pedal and went thru the modes.
#9 | |
I'm not saying the switch isn't bad, but before you drop whatever at the junkyard or a new one at $140, make sure you test out that wire thoroughly. The factory service manual will have the correct info (available at a library) or see if ChevyTech chimes in with his vast knowledge and collection of diagrams. Or get another motor and see if it works.
Mike |
#10 | |
Moderator
Good call. Didn't catch it. Thanks for posting those BTW, they are very handy to have around.
Mike |
Moderator
Sounding more and more like the switch.
Who Me?
That’s what I think also. Is that something that can be replaced by itself Instead of the whole control panel?
Who Me?
The problem switch on the left is attached to the board with the middle switch and the two push buttons. It doesnt look very serviceable.
#15 |
Moderator
Difficult at best.
Usually it's not the rotary switch itself. The control circuit causes issues. It's all one part and I never took the time to troubleshoot what actually failed on the boards. There are one or two T92 package transistors and at least one electrolytic capacitor IIRC.
#16 |
Who Me?
I appreciate the help with this issue. I will check some local salvage yards for a replacement control panel and see if my issue changes. New part are $140+.
#17 |
#18 |
Who Me?
Thanks Speedy, but my issue is with the mode switch. My blower speed switch works fine at all speeds. Im having issues with changing the wind direction.
#19 |
Moderator
They can probably be repaired if you have the tools and experience...
My bench toys... You don't want to see the workbench right now.
#20 |
Who Me?
What is your shipping address again? LOL! You look like the right man for the job!
#21 |
Moderator
I only do repairs for Myself, close family and, for my employer.
My hourly rate would make a new controller look real affordable. I don't have an accessible test bed for that controller right now either.
#22 |
Who Me?
The motors are much cheaper.. I will also reference the manual. Thanks!
#23 | |
Moderator
I'd troubleshoot it using the service manual if you can. Way cheaper than the shotgun method. I won't be shocked to hear it's the controller. I've never seen a failed motor just stripped gears. Testing is free...
#24 | |
some wd40 might free it. |
