12-24-2018, 05:05 PM | #1 |
7.4 to 8.1, was it worth it?
G'day y'all and a very Chevy Christmas.
I have been looking at pulling my old 1993 7.4 and doing crank rods pistons and bore to go out to 8.1 (496). For those of you that have done this...was it worth it and what hassles di you encounter. I know that I will need to oversize the TBI and get the computer redone, planning on a set of new mufflers (I want a deep tone but not loud). I only use it for occasional driving, towing 20' trailer (tandem tilt) and truck camper (2002 Summerwind 911S). Running duel fuel at the moment ( pump gas and propane). The cost of pump gas down here is really expensive. Did your fuel consumption go thru the roof after the initial run-in had been done? TIA. |
12-29-2018, 10:35 AM | #2 |
Re: 7.4 to 8.1, was it worth it?
I have 2 454s that have been built- one a 468 and one a 496. They both the same mileage as we get out of our 454 tbi. Actually the 454 gets the worst of the bunch. Tbi 454 gets 9.2 and 468 with sniper efi gets 11
You would need heads and a cam also. Stock tbi cam and heads are pathetic in a 454. Adding cubes would make it worse. |
12-31-2018, 08:11 PM | #3 | |
When I first got my Burb, which came from California, its mileage immediately improved by 20%. Happy New Year
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
12-31-2018, 09:46 PM | #4 |
best part of propane or natural gas feeding it is SUPER clean inside the motor . i have seen a few torn apart after 100k miles and there like new inside .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-31-2018, 11:12 PM | #5 |
Well hopefully we will see similar results in June. I want to take it out to 496. This will be the motor to see me out and plenty left for the future.
12-29-2018, 07:27 PM | #6 |
G’day and thanks Tiger Joe. What heads and cam did you go with. The pump gas down here is about $6.75 per gallon, thats why i asked what milage y’all are getting.
12-29-2018, 10:08 PM | #7 |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-29-2018, 07:43 PM | #8 |
I run stock 781 heads on my fuel injected 468. Cam i don’t have specs but it’s a roller cam built for towing
12-29-2018, 08:11 PM | #9 |
good stock gm heads are 049 or 781 for the last 3#'s on the casting under the valve cover . there large oval port for good power and can be a few simple mods to weak them up with bigger valve swapped in them .
if your never going to spin crazy rpm of 4k plus then some guys like to use peanut port heads for the bottom end torque they make but fall flat after 4kish .
12-30-2018, 12:53 AM | #10 |
Just saw gas here the lowest in years $1.95 a gallon US.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-31-2018, 05:50 PM | #11 |
Thanks for the help everyone. The price of pump gas down here is the main reason that I run dual fuel, always start on pump gas and when the temp gauge starts to move I switch to propane. This has made it affordable to put 430,000 kilometres on it with out any major faults. It has had a set of valve cover gaskets, a distributor and a water pump. I would say it has served me well.
01-01-2019, 02:46 AM | #12 |
Can't you run much higher compression and be dedicated propane and gain mileage and power ?
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 Last edited by 68post; 01-01-2019 at 02:57 AM. Reason: add |
01-01-2019, 09:14 AM | #13 |
01-01-2019, 01:28 PM | #14 |
My experience with propane is, you get less “bang” and consequently get considerably less fuel mileage. Do y’all have a different experience?
When propane was $.80/gal us, and gas was $2.00 it was well worth it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-02-2019, 07:16 PM | #15 |
Clyde65 , Efficiency would be increased with a much higher compression ratio (as much as practical), and that would make it a "dedicated propane" engine.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
01-03-2019, 12:40 AM | #16 |
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60 Detroit locked/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
