05-15-2019, 12:12 PM | #1 |
Can i use this intake with this rusty surface?with gasket sealer?(pic inside)
Hi i have a question the only intake i can find at a wrecker in my province without spending like 400 on a edelbrock was this one,i have been searching with no luck for a replacement,,, it has some rust/pitting issues on the surface under the egr side, i was wondering if i clean it up real nice with a very fine grit sandpaper and then use that permatex ultra copper max temp gasket sealer thats good for like 600f with a putty knife and fill in the divits,this engine uses a metal valley pan instead of 2 long gaskets, if i make it flush it should seal until i find a replacement later on? any thoughts or opinions would be greatly valued,* i understand i should replace it, but do you think my divit fill in would do the trick for now? other side is shiny smooth)
thankyou for taking a look |
05-15-2019, 12:26 PM | #2 |
Re: Can i use this intake with this rusty surface?with gasket sealer?(pic inside)
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
05-15-2019, 12:38 PM | #3 |
Spring time in Saskatchewan, yet!
Don’t bother filling it. Use some right stuff sealer on both sides of the pan and bolt it on. Do me a favour! Say howdy to my relatives for me! My dad was born in Cupar |
05-15-2019, 02:46 PM | #4 |
2nd skipping the sanding. Instead use a wire brush(hand or drill powered) to clean most of the rust out of the pits. That way, the sealer will do a better job of sealing.
05-15-2019, 05:17 PM | #5 |
ok so i did some work on it and this is what i have now, i was suggested to fill in with jb weld the pits and sand level, i was thinking just that high temp copper permatex to fill them in and let it set so it has some flat sealing cusion if i could get opinions after i sanded and worked it a bit.
the other side came out great, i didnt really want to work that spot too much and take too much off of it so im hoping it will seal, but this is what it looks like after, i dont feel as stressed using it as a temp for now just as long as i get those divots sealed,lol * sorry if the pics big* |
05-15-2019, 05:46 PM | #6 |
You’re over thinking it.
I’ve seen worse that sealed up with a smear of form a gasket. |
05-17-2019, 10:22 AM | #7 |
05-17-2019, 08:00 PM | #8 |
Just add some RTV and slap ot on
05-18-2019, 09:54 AM | #9 |
I second the RTV-It will be fine.
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
