New C50 Owner
One happy guy (I think).
Just bought this 1969 C50 grain truck.
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). |
Re: New C50 Owner
Congrats.
As mentioned in the other thread, it's an impressive truck. Keep us posted on it.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
![]() Join Date: Mar 2003
Re: New C50 Owner
Wish I could find something that nice closer to me
#4 | |
Re: New C50 Owner
It's 1300 miles from me, so I'm still figuring out the logistics of getting it home.
Re: New C50 Owner
Does Florida allow you to purchase one way trip permits? If so purchase one and fly out and get it. You will have a wonderful time driving it home! Even better take another person with you to share the experience. My son Noah and I talk all the time about the fun we had resurrecting my C-70 and driving it 800 miles. Great memories.
David https://67-72chevytrucks.com/vboard/...d.php?t=721374 |
#6 | |
Re: New C50 Owner
Re: New C50 Owner
Be sure to check the brake fluid before pressing the pedal. If it is low, it will usually self bleed unless the pedal gets pushed. Top off the master cylinder and wait for the air bubbles to stop. The rear brake cylinder is easy to replace, you could order a pair, rock auto is a good source, and have them with you in case they were needed.
David |
Re: New C50 Owner
I would not hesitate to take the truck on the interstate. Looking at it I believe it has been well maintained by someone who knows how to do it. It appears to have had radiator hoses replace in the recent past, nothing appears to have been rigged (like most farm vehicles). I suspect the 292 would hum down the road just fine. I used to drive a 1972 with 4 and 2, was a great road machine. I would expect it to be governed at 60 MPH, as all truck of that era were. Just hold the pedal to the floor and enjoy the cruise.
David |
Re: New C50 Owner
Keep it at around 60 and put hazard lights on, you will be fine.
Re: New C50 Owner
That is how I drove them back in the day. They were designed for 60 MPH. It will seem like the engine is winding fast compared to modern vehicles. They were geared to carry heavy loads all day long at highway speeds.
Re: New C50 Owner
The 292 was a great motor, had lots of torque, would pull 300 bushels of grain out of a field easy.
Re: New C50 Owner
#13 | ||||
Re: New C50 Owner
Thanks. I can't wait to get it here. Quote:
I'm too old and too poor to break down 1,000 miles from home in 30 degree weather.
#14 | |
Re: New C50 Owner
#15 |
Re: New C50 Owner
Well, so much for that idea! I just found out that the only place I could find that rents trailers big enough, does not allow vehicles on them (????) and does not allow them to leave the state!!!
I'm so pissed, right now, that I can't even see straight! Who would have thought this would be this big a problem?
#16 |
![]() Join Date: Jun 2017
Re: New C50 Owner
That's clean and good looking truck!
#17 |
Re: New C50 Owner
As others have said, nice looking truck! I don't know how keen I'd be on taking an old truck I had never seen before and bombing it at 3500+ rpms for 1300 miles. Sure, it was made for that, I agree! But that was 50 years ago too and if it's only been run local and you take it on that sort of trip there's no end to the things that can start to go wrong a few hundred miles into your journey leaving you to do some roadside wrenching that could be anywhere from a minor fix to a huge conundrum.
Not trying to be a downer! I'm firmly rooted in the "drive it home" camp, just with the knowledge that you may want to prepare and take an array of tools and some spare belts, hoses, thermostats, air filter, etc, etc... |
#18 |
Re: New C50 Owner
These trucks get the grain dust and dirt blown off them every fall harvest and run hard all day long full throttle to and from the field and grain elevator. Going down the road empty would be a walk in the park. Given the apparent care it has had, doubt you would have any issues. Several hundred miles a day was normal during harvest.
#19 |
Re: New C50 Owner
I would be torn on a 1300 mile trip with an unknown truck. On one hand it looks well taken care of but on the other hand just how well has it been maintained mechanically. A 50 year old truck has a lot or unknowns. It looks like the truck wasn't used a whole lot or at least not abused when it was used. If the previous owner did a lot of things as preventative maintenance I would roll the dice on it.
At minimum I would have a trail car loaded down with everything possible for a quick road side fix. That's what I did with mine but mine was only a couple hundred miles from home. I had every tool I could think of. About the only thing I didn't have was a cherry picker. Don't forget to factor in the weather too. At 60 mph non stop you're talking 22 hours of drive time. That's at least one night in a hotel. On the high side of 8 mpg that's around $400 in gas alone. So with all that figured you're at a low side of $650 for a hotel and gas. That's not including driving or flying to the truck either. I would go for it if it were warmer outside. Like Airdirect said it will make for some great memories. |
#20 |
Re: New C50 Owner
Nice ride!
I bought my 1987 C60 about 400 miles away. Had 49,000 original, ran out decent, everything looked good. So I decided to drive it back. About 1/3 the way back, it decided to launch the alternator belt, which then got caught in the fan, and took out the upper radiator hose. It ended up with an $800.00 tow, which my wife still reminds me of..... |
#21 |
Re: New C50 Owner
#22 | |
Re: New C50 Owner
Thanks, though.
#23 |
Re: New C50 Owner
I had luck on USHip getting my C50 down from northern CA as long as you put out all of your specs on the truck and its estimated weight as long as it is fairly close to a popular route or someone has an empty trailer coming back and can grab it.
Just make sure you don't get caught up with a Broker and their stories when they put the load out on the "dispatch board". They'll say they'll have it picked up in a few days and to you in a few days yet weeks can go by before you even hear back from them.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint) 1969 GMC C10 Pickup SWB Stepside (heart transplant) 1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts) 1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts) Last edited by txagincali; 01-02-2020 at 08:04 PM. Reason: Specifics |
#24 | |
Re: New C50 Owner
Can you specify, on uShip, that you don't want a broker?
#25 |
Re: New C50 Owner
I would never use Uship again . If you are on FaceBook there are independent carriers that will bid for your load , no brokers to deal with .
