K20 with TH350/NP205
Looking for some input from anyone with a 3/4 ton 4x4 that is running a TH350 / NP205 transmission.
I have a 1978 K20 with this transmission / transfer case combo and will be putting a stock 454 big block in place of the tired 350 this year. The transmission currently functions perfectly, but I am wondering if I should swap it to a TH400 / NP208 or just rebuild what I have so I don't have to change my whole driveline around. The truck is used for weekend driving, picking up mulch and some towing, nothing too crazy. I rarely if ever take it off road or beat on it. |
![]() Join Date: Mar 2003
Re: K20 with TH350/NP205
T350 transmissions were not really designed for the torque of a big block. With that being said....my tree guy has a square body 3/4 ton 4x that somebody hacked a 454 into. Still has the 350/205 combo. He's been driving it that way for years. He just putts along, but he does occasionally tow a small chipper with it.
friend of mine has been running them for years built with ood parts and biggest clutch pack options .
he did one for me and my built 400sbc with 4.10 gears and 38" swampers on 1ton axles i run for years . heat is the #1 killer with dirt #2 just behind it .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#4 | |
The TH350 was the weak point of the whole pickup, and I traded it off for a 4 speed. The NP205 that you have is the strongest transfer case, though not the lowest geared. Why don't you just rebuild the 350 V8 ???????
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
BlahBlahBlah
I think if you are wondering whether a big block 454/turbo-350/205 combo is strong enough you should contact Livrat here on the board. He ran that combo for years in his 68 GMC/Chev K20 and used the truck to haul heavy loads and pull a heavy trailer all the time.
![]() Join Date: Sep 2009
If you havent all ready bought the 454, I'd do a serious checklist of all its gonna take to swap in the BB. motor , exhaust, accessories, labor to move the trans/TC back, drive shaft changes etc everything.
then price up re-build on your 350, maybe turn it into a 383 and put it right back in. |
#7 | |
![]() Join Date: Jul 2015
I have a TH350/205 in my LS swapped 72 K10. The transmission shifts good and truck doesn't vibrate at 70 on the freeway. The 6.0 is around 300hp..
What most people don't realize is the TH400 takes about 15HP more to drive then the TH350..
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
#9 | |
Reason I ask is that my observation was that a TH350 sucks off about 35% of your power compared to a manual transmission.
auto does eat more than man trans .
if your not driving it hard, I'd think you will be fine. I had a 79 Malibu that was a factory 4-speed Saginaw. I've heard and read everywhere that they were the weakest 4-speed GM built. I had a healthy 454 that I put in, guessing 400 horse. I can't drive a stick very good, more used to truck 4-speed and I have a CDL, so big truck tranny's. Well, I beat that tranny pretty good, and it would sorta hook, posi with 295/50s, but really romp in it will would spin. Tranny never even sniffled. A TH350 is definitely stronger than a Saginaw, tho it is in a heavier vehicle. But as mentioned, get a good cooler, maybe an inline filter, I think you will be fine.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
My truck has been running a fairly strong 402, turbo 350/205 for years.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() ![]() Join Date: May 2015
Gmc20..heres some info...https://www.carsdirect.com/car-maint...-transmissions
#14 | |
