Mega Fuse Mounting Place?
I have a 69 GMC and a American AutoWire kit.
Where did you guys mount the mega fuses? There are lots of options (frame, fender, firewall, ect.) and I can decide on the best. Thanks |
Re: Mega Fuse Mounting Place?
I mounted mine under the heater box close to the right inner fender. Easy to see and easy to replace if needed. I carry an extra fuse in the glove box but have never need it.
Thanks, thats the general area I think I will end up at. I'm thinking lower passenger firewall. With my nice new wire harness I wanna keep it clean.
I'm just wondering what other folks have done. |
No more megafuze for me.
![]() Join Date: Mar 2015
That doesn't look like the mega fuse that came with my AAW kit. Here's where I put mine, pretty standard placement.
Just make sure it's close to battery too.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
Old member
Fuses should always be a close to the source as possible. The shorter the better it will work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
