![]() Join Date: Feb 2001
Gas leak
Got uo this morning and smelled gas … looks like I have a leak on the Circuit Rider …
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
![]() ![]() Join Date: Jul 2002
Re: Gas leak
Just in the cab or is the smell from outside also?
Re: Gas leak
Outside ... I think I saw a small pool of gas on the cement under the engine.
![]() Join Date: May 2012
Re: Gas leak
Maybe not, if you don't actually see gas leaking. My garage stank like gas for months, I got sick of it. Installed a WIX - 33054 and recirculated back through the top of the fuel sending unit. I wasn't happy about having to do it but the gas smell in my shop is gone. Worked like a charm. If you can't find a leak you may be heat soaking and boiling off.
good luck! j
White K20 |
#5 | |
![]() Join Date: Jul 2000
Re: Gas leak
I should have asked what's the theory behind using it.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#6 | |
Re: Gas leak
The theory: (and short answer) It's not really a theory, but a fact that today's fuel has a lower boiling point. When you shut down your engine the temps under the hood get even hotter, no water or air circulating. The fuel in the pump and carb starts to boil and creates pressure and floods the carb. If you have trouble starting your truck 10-15 minutes after sitting and it starts like it's flooded, it's because it is. And that's the gas smell. I drive my truck in 110+ heat here. The solution works for me. But after hard runs in extreme heat I still sometimes get the hard start, but it's very minor now, just a slight tap on the gas pedal and it fires up. It used to be real bad and my garage reeked like a gas spill. But I never get the gas stink in my shop anymore. Easy solution and it worked for me... just annoyed about having to hack into my solid fuel line. ![]() j
White K20 |
Re: Gas leak
I understand the boiling problem, but not how this solution addresses it. How does sending a small amount of fuel back to the tank prevent fuel in the float bowls from boiling?
#8 | |
Re: Gas leak
![]() j
White K20 |
