![]() Join Date: Jun 2023
Billet or OEM style carrier bearing??
I am going to replace the carrier bearing on my two piece C10, is there any plus or minus to putting in a billet style bearing or would the factory style b better? What's your experiences?
Re: Billet or OEM style carrier bearing??
I recently replaced the carrier on my two piece shaft with a stock style unit. If you go with one of those, I would suggest welding the base plate around the edge. These are normally just tacked on and tend to break free, leaving you with a floppy driveshaft. If you go with billet aftermarket, it has negligible fore/aft play so you will need to have a driveshaft with a slip yoke on the rear or else you are going to be hammering that poly mount every time your suspension travels. Either mount will get the job done if installed properly.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#3 | |
![]() Join Date: Sep 2005
so ive boken many stock carrier bearings over the years, but then i did my ls swap, had my drive shaft shorted i asked the drive shaft shop the same question, he told me to runn the aftermarket billet bearing i would have to add a slip yoke into my drive shaft. he said the stock bearing as been around for years and the biggest reason they fail is the drive shaft is out of balance or when someone changed on they put the dirver shaft back together out of phase thus making it out of balance, i stock witht he stock bearing he blanced my whole drive shaft as one unit, its been 9 year not and ive yet to brake a stock carrier since then and i beat the daylights out of my c10 with ls swap
Thank you!
