12-15-2023, 08:55 PM | #1 |
My low(ish) budget OEM build
Hi there. I decided it was time to get started on this swap. I picked up a 4.8l, 4L60e, and all the bits and pieces from FB marketplace. I didn't see the truck run, but I did see a video of it running. Nothing like starting with all the best parts! The goal is to keep as much of the setup OEM. I'm not really looking for power, just a little reliability and comfort. Anyway, here is where I'm currently at.
12-16-2023, 06:32 AM | #2 |
Re: My low(ish) budget OEM build
You'll like the little 4.8. Like you, I wasn't looking for heaping helpings of power, but just good reliability and maybe a little bit of fun. I swapped a 4.8/4L60E into my '89 c1500 and am Very pleased with it.
12-16-2023, 10:01 PM | #3 |
Well, the engine is in, but I've run into a problem. The oil pan is sitting on the center link. I need to raise the engine up about 1/2". I think I've decided to do this by building spacers to go between the frame and the mount brackets. If someone has a better idea, please let me know.
12-16-2023, 11:45 PM | #4 |
Oh, and one more question. How much engine angle is too much. I measured the 350 before I took it out and was surprised to find it at about 6 degrees with the frame rails level. For me to be able to clear my trans hump, I'm probably going to have to be between 6 and 7 degrees.
12-17-2023, 05:15 PM | #5 |
Spacers should work fine. I would try to get the engine angle to 5 degrees or less. On my 68 with a LS6/4L60E combo was right at 4.5 degrees but I had a high hump trans tunnel. Zero issues.
12-23-2023, 06:21 PM | #6 |
Well, no pictures today, but I got the motor mounts sorted. I ended up making spacers out of PTFE. It's easy to work with and will last forever. A super cheap way to get thick pieces of PTFE is to buy a cutting board off Amazon. I had some 1" thick stuff laying around from an old project, so I used that. I "milled" it down to about .675", which gave me plenty of clearance to the center link, but allowed me to get a decent pinion angle. I'm at about 5.8 degrees. The bottom of the pan is 2 degrees back. I still have to make a trans crossmember, but it's going to be super easy.
12-26-2023, 10:54 PM | #7 |
I managed to get quite a bit done today. I fabbed the trans crossmemeber and got it installed. I was able to get the tailshaft very close to the original location. I wont have to modify my driveshaft at all. I also got the water pump installed.
I am using ICT billet accessory mounts, and I'm very happy with the construction, but they are raw billet. The are not shiny at all. So, I've decided I'm going to polish them. Next time, I'll post a pic of my polisher. It's some fanatic old school thing that I got from my buddy's dad when he retired. Last edited by LockDoc; 12-30-2023 at 11:58 AM. |
12-26-2023, 10:56 PM | #8 |
Oh, and here is my crossmember next to the abomination that I removed. It was held in with 2 bolts
12-29-2023, 12:11 PM | #9 |
Looks good
Question, why not use the stock transmission crossmember? I suspect you needed it to be lower for clearance? If trans is 7⁰ down the axle pinion should be 7⁰ up. The engine/trans doesn't know that it's tilted except for the fluids. Since the engine/trans is an oil pressure system you should be fine. |
12-31-2023, 10:19 AM | #10 | |
I got the rest of my ICT brackets, so I got those polished up and mounted. I painted the alternator black to go with the theme. I'm now in the middle of building my fuel system. I'm going with an inline pump since I can't find a tank that fits my needs. I bought a good one, so hopefully it holds up. I spent quite a bit of time mounting it. I have a pretty novel idea for trying to keep it quiet. No pictures of that yet, but I'll get some as soon as I get back under there. And as promised, here's a pic of my polisher. |
12-31-2023, 09:01 PM | #11 |
I've used tanks inc for tanks, fuel pumps, etc,ect. Pretty good pricing compared to the other folks.
I've had pumps in tank and out, but in tank is preferred. (not just for noise, it keeps the pump cooler and away from tailpipes and other stuff). https://www.tanksinc.com/index.cfm/p...rod/prd925.htm PS> I am a full believer in the "low budget, use OEM stuff" plan. I'm a little surprised you wasted money on aftermarket brackets, but OK, you need a little bling. One thing I have been frustrated by: fuel hose, most brands of fuel hose are crap. You MUST replace it every 5 years or so. (ie I recommend making steel lines with 8-10" rubber pieces wherever required for vibration or flex. Last edited by cj847; 12-31-2023 at 09:19 PM. |
01-21-2024, 11:42 AM | #12 |
i did a 4.8 4l60e in my 71 i love the swap its a fun fast truck
01-24-2024, 03:26 AM | #13 |
There are other options than the old school fuel systems for your modern LS. Offered by most with their tanks. Check out https://www.vaporworx.com/ A modern deadhead fuel control system that uses oem components for the LS that will last for about the same cost as the return system.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-30-2024, 07:39 PM | #14 |
Well, it's been a winter. Today was my first start. I got it off the stands and took it around the block. Everything felt really good. I still don't have the hood on it, and the bed is still full of crap, so I couldn't go far or fast. First impressions are great.
I've got a couple of issues to sort through, which is to be expected. 1. I have codes for the heater circuits for both O2 sensors. 2. My throttle pedal is not very comfortable. I need to move it away from me. If you have any recommendations on a DBW throttle pedal, please let me know. |
03-30-2024, 08:58 PM | #15 |
Congrats on taking your swap on its first drive! That is an exciting time. What throttle pedal are you using? When I did my swap I had the same issue with the uncomfortable pedal. I used the DBW pedal from the 2004 donor truck I got my engine from and mounted it with a bracket I got from a board member. It was way too far off the floor. Although the bracket gave me full travel on the throttle sensor, that was not necessary. These engines reach WOT at about 50% sensor travel. So I used a scanner and figured out where WOT was and then angled the pedal down so that the pedal was on the floor at WOT. After that, it was much more ergonomic. This is a photo after I adjusted the angle of the pedal.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
03-31-2024, 07:40 AM | #16 | |
Junior Member
Congrats on the first drive! I actually did the same yesterday with my LS swap - drove to the store to gas up! |
03-31-2024, 08:03 AM | #17 | |
04-01-2024, 06:42 AM | #18 |
That is correct, I just added a plate to space the top out. The bottom still attaches to the bracket as intended. I got the bracket from here: https://67-72chevytrucks.com/vboard/...d.php?t=651123
03-30-2024, 08:56 PM | #19 |
On my LS3/L92 swaps I use a DBW pedal supplied by the folks at either Howell or Speartech. I would contact them and talk to them about your combo and see what they can supply.
04-05-2024, 12:25 PM | #20 |
Ok, now. Time for first impressions. I was able to fix the last of my electrical problems. The truck is charging. The oil and temp gauges work. The speedo works, but still needs to be calibrated.
The truck drives wonderfully. The suspension is soft (which is fine), brakes feel good, and the steering feel is just like any other traditional PS setup. I was a little worried about the pump being for a rack and pinion setup, but it feels great. The engine and trans combo definitely make it a little more spunky, but not anything I feel like my 18yo can't drive. With the posi rear, she is very well composed. I'm hoping after a little more shakedown, she can move into my "daily driver" status. Now for the things I may modify. I may add cats. It still stinks, and I'd like it not to. I am definitely going to adjust the gas pedal, and remove the steering wheel disconnect. I need to get it a little more comfortable to drive if I'm ever going to do power tour or something similar. Other than that, it's time to just enjoy it for a while. If money and time allows, I may do some cosmetic upgrades next winter. |
