03-19-2024, 12:29 PM | #1 |
Active Member
Engine code or date code?
Question, my 1969 396 engine has the following stamp on the passenger side: 10 21 YS , is this a date code ?
Thanks ! |
03-19-2024, 12:53 PM | #2 |
Re: Engine code or date code?
the casting date is on the back of the block near the bellhousing flange on the passenger side and its cast into the block not stamped.
I think what your posting is the front pad code, YS comes up as a 69 Truck motor.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
03-19-2024, 01:06 PM | #3 |
Active Member
Thanks !
03-19-2024, 01:09 PM | #4 |
10 21 is the engine assembly date- October 21
YS suffix code is for a 1969 396 truck engine, 310hp, 4bbl carb, manual transmission There should be a letter at the very beginning of the stamped code that will tell you the engine factory. F- Flint, MI (1955-1966) V- Flint, Mi (1967 and newer) T- Tonowanda, NY K- St. Catherine, Ontario S-Saginaw, Mi M- Mexico The date cast into the block is the date when the block was cast and which shift it was cast on.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
03-20-2024, 04:43 AM | #5 |
Active Member
thanks !
03-20-2024, 06:58 PM | #6 | |
I have 292 blocks from '67 and '68 that have F codes in the stamped dress numbers.
03-20-2024, 07:36 PM | #7 | |
03-20-2024, 08:19 PM | #8 |
Then theres this chart from Inliners International, its not clear if the six cylinders remained F and the V8's changed to V. The Lime Book only covers V8's.
https://www.inliners.org/ubbthreads/...t&Number=66011
