1969 Three on the Tree - trans fluid and capacity?
Hi guys, I have a three on the tree in my ‘69
Can anyone tell me what trans fluid it takes and rough capacity? Thanks Also, assuming it’s original, what transmission is this?
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires Last edited by Luke87gt; 04-25-2024 at 01:26 AM. |
Re: 1969 Three on the Tree - trans fluid and capacity?
80/90 Gear oil. I'm thinking 3-1/2 pints but will have to find my manual. If it is in the truck one of those red plastic transfer pumps with the red hoses from Harbor Freight is a life saver. They are inexpensive enough to have one for each type of fluid you would pump with one and not cross contaminate.
![]() Join Date: Dec 1999
This is what I use in mine:
https://www.tractorsupply.com/tsc/pr...-2-gal-t806600 The GL-1 rating is safe bronze and copper(one or both are present in the 3 speeds) There's much discussion about this on this board and many others. But my deduction was the a GL-1 Rated 90w Gear oil is the safe choice. |
#4 | |
Active Member
![]() Join Date: Sep 2023
I would go with a good 80W90 oil just my opinion David
Old dogs and children and watermelon wine ![]() |
Yuppers, there have been a ton of advancements in gear oil and oils in general since that Ford tractor formula was created. A good quality 80-90 would be far better. Leave that stuff to the antique tractor brigade.
Apparently NAPA has 1 gallon for the price of 2 at tractor supply if that is more convenient for you.
https://www.napaonline.com/en/p/NHF65201 |
Thank you for the replies everyone.
Will use the gear oil recommended above. Lastly, what transmission brand/name is this?
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
#8 | |
https://lugnutz65chevystepside.weebl...ission-id.html |
#9 | |
Based on the 7 bolt cover, and placement of bolt holes, it appears to be a Saginaw 3sp manual Is that good or bad? Lol
#10 | |
![]() Join Date: Jul 2000
Useless information? ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Just like a differential. Fill it until lube runs out of the fill hole.
Most gear oil bottles have a nozzle, so unless something is in the way, you can just stick in the hole and squeeze.
Good trans.
Lighter duty. The Muncie was supposedly heavy duty. |
![]() Join Date: Jul 2003
Just make sure the fluid is GL4. It's compatible with soft metals.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Oh, can anyone confirm the three gear ratios ?
Also, what is my factory rearend gear ratio in my 12 bolt?
#15 | |
![]() Join Date: Feb 2002
B]...If originally equipped with an automatic transmission, a 3:08 differential gear set was installed. If Manual, 3.73 was standard. If not noted on the SPID Then it was one of these.
#16 | |
I’ll try to confirm it by doing the wheel rotate / driveshaft count
#17 |
Factory issued info:
#18 |
GL-5 80W or 90W was recommended then..
