Square Body Tahoe
Hi all, I was wondering if anyone has pics of the rear floor area (without carpet) for a 1998ish 4-door Tahoe/Yukon. I was trying to see how the rear area is shaped/constructed; thinking about making a 4-door square body Tahoe if I get a hold of a square body suburban body. Basically I'm trying to see how the rear wheel tub area looks, the door pillar area around the wheel opening, and how the floor is constructed to support the 2nd row seat. I know it'll be a lot of work to make it, just trying to get an idea of what all would have to be done. Thanks
Re: Square Body Tahoe
here is a 68 kinda give you idea but he made it into a 2dr
https://www.fuelcurve.com/ghoesst/ |
Thanks; that is sweet lookin'! I think to make a 4-door tahoe, I figured I'd need a 2-door short box truck frame for the correct length. I'm basing my measurements off of the 88-98 trucks/burbs/blazers. Here are some photoshops I've found of Tahoes; I love the stubby look they have. The blue/gray Tahoe I feel is more accurate; the orange one's wheel well goes too far into the rear door I think. Thanks
https://www.instagram.com/p/BiiUkZOn...by=iceman_deck
just seen this one look like shortend door other one the did back instead |
I can't see it; don't have an Instagram account. Thanks
square body wheelbases:
Blazer 106.5" SCSB 117.5" Suburban 129.5" SCLB 131.5" Crew Cab 164.5" GMT400 wheelbases: Tahoe 2dr 111.5" Tahoe 4dr 117.5" SCSB 117.5" Suburban 131.5" SCLB 131.5" ECSB 141.5" CCSB 154.5" ECLB 155.5" CCLB 168.5" While the 4dr wheelbase matches the SCSB, I know that on a square body the frame is shaped significantly differently between trucks and Suburbans. With the amount of work you're putting into the body I'd be tempted to just build a frame too, so you can do it how you want it (I assume boxed, set up right for links, etc)
1973 C20, 350/350 |
the pic of the 75-76 supertahoe is a new one on me.. I never have seen one like it did gm ever make these??
4x4k30 if trouble was money i would have plenty |
GM never made one. I don't know if any aftermarket companies did (I believe one made some extended cab squares).
1973 C20, 350/350 |
Yeah this is the picture they got it from. The brochure was for a 1978 suburban. Thanks for the wheelbases. Slotard, do you know the wheelbase for a 73-91 crew cab short box? I know GM never made one, but I'd like to know the wheelbase. I'm assuming it's about 33" longer than a regular short box. Found a potential crew cab project. Included a pic of an extended cab square body also for reference (not mine). Thanks
![]() Join Date: Jun 2017
crewcab short box is 14" shorter than a crewcab longbed.
CCLB is 164.5" CCSB is 150.5" edit, I could add- RCSB- 117.5 RCLB- 131.5 so the crewcab adds 33". long bed adds 14".
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
