09-05-2019, 12:46 AM | #1 |
BBC into Camaro Sub frame?
Hello all,
I have another question for the engine gurus! It's looking like I'm gonna have to pull my fresh 383 out of my '59 Apache, with a '79 Camaro sub frame. I have a built, turn key BBC ready to roll. I know that I'll have to change my spring rate, as my truck already sits LOW in the front (drop spindles and Eibach springs with half a coil cut off). My question is, will (should) a BBC fit into the hole that the SBC came out of? I don't see why not! I had a SBC in my '68 previously, with the POL engine mounts. Obviously headers, etc may be an issue, but as far as physically fitting, the BBC should bolt right into place where the SBC was, right? I've been torn on which truck should get the big block. Previously, I wanted it in the '68, but I'm probably going to sell that truck. So, it may get my 383, and my '59 may get the 496 BBC! Thanks! Nik
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
09-05-2019, 07:06 AM | #2 |
Re: BBC into Camaro Sub frame?
Gen 2s came factory with a big block so dunno why wouldn’t fit...
09-05-2019, 11:19 AM | #3 |
If your using the factory small block mounting position you likely need the big block version.
You modified one major point, and thus you've likely modified others. You really should set in in the truck to see if it fits. I would take the front clip off so any mods would be easier. |
09-05-2019, 11:09 PM | #4 |
Yeah, I need to just drop it in there. The '68 has had both a small block and a big block in it, with POL frame stands. That tells me that the engine mount bolts are in the same location. Might not work with SBC mounts, due to oil pan clearance. Just kicking it around.
