10-27-2019, 12:12 PM | #1 |
Utility box removal
Hi everyone. I'm looking at buying an 84 C20, with a utility box with liftgate, and if I get it, want to replace it with a standard longbed. ( I don't want a short bed). I ve looked on YouTube, and did Google searches but can't find out how to do it except on new trucks. Can anyone help me with this?
TIA |
10-27-2019, 01:44 PM | #2 |
Re: Utility box removal
I have seen them mounted with the just the outer four stock location bolts and the factor 8 bolt holes. More than likely it uses the front 2 bed mounts and the 2 rearward ones. That is the setup I have seen most. Once they are off, disconnect the fuel filler tube and the wiring for lights, then it just lifts off like a factor fleetside bed.
10-27-2019, 02:44 PM | #3 |
Thanks. I should be able to drop a long bed on in place of it, right?
10-28-2019, 10:37 AM | #4 |
Depends on if its a cab and chassis or a regular pickup frame. A regular pickup bed on a cab and chassis will end up with a couple inch gap between the cab and bed.
10-28-2019, 10:53 AM | #5 |
Is there a way of telling by looking at it, or only if I remove the utility box?
10-28-2019, 11:00 AM | #6 |
Should be able to look at the VIN to determine if it was sold as a pickup or cab and chassis. I don't know the digit or code to look for though.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
10-28-2019, 12:02 PM | #7 |
IIRC it is 56" from the back of the cab to the center of the axle on a regular pickup and 60" on a C & C.
