![]() Join Date: Sep 2002
Factory Steering Column to S10 Gearbox
Just thinking ahead before I go to pick up my next project... (Edit: S10 swap)
I would like to keep the factory column in my 51. Here's what I am thinking... I would use a lower bearing conversion along with the firewall mount like my 66. The only thing I am not sure of at the moment is if the location of the column firewall hole will be in a flat location and if the inner shaft is long enough to reach the gearbox. Also, the donor column is out of automatic truck! I believe I was told it's a 54. The transmission is a cast iron case. I never knew autos were available that early, especially in trucks. It has a nice shift indicator too. It also has what I believe is the original strap-on turn signal switch. ( I saw another truck with the identical switch installed). Don't have a photo of that. And one more thing... Is the steering wheel splines and taper the typical size? (If there is a standard size). Thoughts? Last edited by damnyankee36; 03-07-2023 at 03:12 PM. |
#2 | ||
![]() Join Date: May 2007
Re: Factory Steering Column to S10 Gearbox
answering your questions in order:
good luck!
#3 | |
I'll look closer at al the S10 swaps here to get a better feel on how this job is typically done. |
#4 | |
yep 54 and 55 were the first for optional turn signals on the column! if your donor column is a 54 hydromatic, there is a good chance it has turn signal switch too.
sounds like you have an automatic trans from back in the day. very heavy, some didn't have a park option. there are those who would likely pay big for that, if you wanted to sell it and upgrade.
ifyoure thinking of an S10 swap, private message joedoh, he makes the mount kits for the AD trucks, nice ones too. he could do an S10 swap in his sleep I think. lol.
![]() ![]() Join Date: Oct 2014
Yep, here's his ad in the vendor's section.....https://67-72chevytrucks.com/vboard/...d.php?t=832482
#8 | |||
I think I'll be giving you a call Joe! |
the stuff that joedoh makes is what he uses and he has built lots of different combinations. figure out what you have for year of old truck body and the frame you have to swap under it (year, length, type of cab it had etc) and send a pm. I'm sure he can help you out with what you need along with ideas of stuff you should pilfer off the swap S10.
