Old 02-27-2018, 03:01 PM   #1
BigDan3131
BigDan3131's Avatar
Question 65 GMC Coil Springs
Pretty simple question, my truck had the 305E in it but I'm switching to an iron headed 408/4L80E and that's a BBC. Should I swap out the coil springs for proper BB ones or will I be okay with the heavier duty 305E springs?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-27-2018, 05:06 PM   #2
mikie 1954
Re: 65 GMC Coil Springs
I am no expert but I would say you will be fine. Theres little differance in wait between a bbc and a 305 v6. then you are using a trans that is lighter than a 4 speed( if that's what it had to begine with)
mikie 1954 is offline   Reply With Quote
Old 02-28-2018, 12:58 AM   #3
Captainfab
60-66 Nut
From past experience I would say that your truck will sit higher in the front with the BBC versus the V6 if retaining the original springs.
