C-60
Sorry I have to ask a dumb question.
I'm looking at a 1960 C-60 truck, all original low miles 63K in good shape. But my question is what is a C-60? 2 1/2 ton? 2 ton? 5 ton? It has a two speed rear end, 4 spd trans, PTO, duel tires on the rear axle so I know it is a heavier duty truck but I'm not sure what it is. Thanks |
60-66 Nut
Re: C-60
A C60 is considered a 2 1/2 ton. I don't remember just what the GVW is on a C60 even though I own one
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-04-2010 at 12:59 AM. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: C-60
The rating is really based on the axle capacities combination front and rear. You can get a 15,000 lb. 17,000lb and a maximum GVW of 19,500 lbs on a C60.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Rottenwood Garage Member
Re: C-60
Remember if you buy it to follow up with your local and federal DOT rules and regulations. Once behind the wheel of that beast you are subject to them.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Re: C-60
Re: C-60
Try to have the truck registered as an antique vehicle, no body in their right mind would use these trucks to turn a profit. Here they classify the vehicle by weight. You can have the weight rating reduced on your registration. Have a public scale receipt to prove how much the truck weighs. Adjust the weight as close as you can to the cutoff point.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 08-04-2010 at 04:06 PM. |
1961 crewcab
Re: C-60
must be alot of people here out of thier mind!
![]() there are about 5-6 roofing businesses here that still use these big guys for thier jobs.. I want 'em all ![]() granted all they do is sit at the job site, and then make a run to the dump.. I would say there are about 10 of 'em still in use around town.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
SSN 706
Re: C-60
Dumb ? Would the doors fit on a c-10?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-04-2010 at 06:39 PM. |
Re: C-60
Had an argument with the licence bureau over the weight rating of the truck to avoid a commercial plate status. Would have to fill out a logbook if I drove further than 100 miles radius from the home base address. Not allowed to cross the border or travel into another province without getting permits. I wanted the GMC 960 for fun not for commercial use. Because of the carrying capacity, I was not allowed to register it as an Antique Vehicule. I stated that it was not for any financial gain, they look at it as for the potential stress that it could exert on the road surface even if the load is yours personally. Bummer! Sold it to a landscaper!
Re: C-60
Doors, cab , hood direct swap!
SSN 706
Re: C-60
Thanks Aerotruk. I was thinking the same I just was'nt sure.
60-66 Nut
Re: C-60
The cabs are basically the same, except they don't have a trans hump.....just flat from left to right side. There is still a removeable access panel there though.
Re: C-60
I`m getting my 63 C50 parts truck, if all goes well this weekend. I want to see what else is compatible.
Example: Motor mount perches, radiator ( someone stole mine out of one of my donor trucks first day when I brought it to work) , clutch linkage etc.
#14 | |
1961 crewcab
Re: C-60
#15 |
Re: C-60
The DOT rules on that vehicle would be....DOT numbers, health card, DOT inspection and log book over 100 miles. Now.....it depends on who pulls you over, with or without and antique tag, as to the end result. With revenue down all these departments are stepping up their enforcement.
#16 |
Re: C-60
Thanks for all the replys!
The truck is in amazing shape for it's age and even has a spare 292 6cyl engine that comes with it. It runs fine with the original engine but extra parts are cool. I fell in love with it because it is so clean and untouched, one owner used on his farm since day one. I will have to check with my DMV to find out what all is involved with being legal with it though. I just want it to haul stuff around for the house or maybe locally load up a car and take to a car show, or tow the car trailer. It would be so cool to trailer my 68 Z/28 with that big beast painted the same LaMans Blue and white as the Z. Thanks again to everyone |
#17 | |
60-66 Nut
Re: C-60
Ohhh! now you did it.....now we're going to have to see some pics of your '68 Z28. You don't see many of them.
