09-24-2019, 05:49 PM | #1 |
Doors
Does any body know if 1967 c10 pickup doors fit on 1967 gmc panel?
09-24-2019, 06:47 PM | #2 |
BlahBlahBlah
Re: Doors
The actual door is the same. The window frame is different. Panel is squared off while trucks are rounded off. Ive never done it myself but I hear its fairly simple to swap window frames. Something about only being spot welded on.
BTW 67-72 doors will fit. There is a little inner door item that's different on 72's because of the plastic door panels, and a little screw by the wing windows, but the doors still fit.
09-24-2019, 06:49 PM | #3 |
Re: Doors
Welcome aboard!
The answer to your question is no, not without modification. If you took the square cornered window frame on your panel door and replaced the round cornered window frame on the pickup door it would work. Suburban doors will work without modification. Whoops I see CG is a faster typist than I am. Never the less welcome and we would like to see pictures of your panel.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-24-2019 at 06:51 PM. Reason: Blah blah blah |
