Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-25-2016, 08:52 PM   #1
68chevycst
68chevycst's Avatar
72 c50 brake problems
I have a 72 c50 and I can't seem to get a good brake petal, I have to pump the petal a few times to get a good petal. Once I have pumped it and push the petal to stop my passenger rear duals lock for a second. I have blead the brakes twice now and is doing the same thing. Do I need to adjust the brake shoes? I haven't pulled the drums yet to look. Any ideas?
Thanks,
Seumas
68 Chevy CST Short Bed, 70 Chevy CST Short Bed, 70 Chevy Short Bed 4X4, 72 Chevy Cheyenne Super 4X4, 72 GMC 1/2 Ton 4x4 Sierra Grande, 72 Chevy 1/2 Ton Big Block Suburban Highlander, 72 Chevy 1/2 Ton 4x4 Suburban, 72 Chevy 1/2 Ton Cheyenne Super, 72 C50 Custom, 69 Chevy CST C30 tow truck, 71 Chevy Big Block C30
68chevycst is offline   Reply With Quote
Old 05-26-2016, 09:12 PM   #2
rkn463
rkn463's Avatar
Re: 72 c50 brake problems
Thanks,
Seumas
On the corner that locks check for shoes contaminated with brake fluid or oil from the axle. I never understood how a lubricant can make them grab but it does. Regarding the need to pump them up make sure the adjusters have the shoes tight to the drums without dragging, if that is good then I'd flush all the fluid, bleed them and see if that gets it. If not then maybe a bad master cylinder.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
