Old 08-11-2022, 07:43 PM   #1
87Skier
87Skier's Avatar
72 Jimmy rust repairs
Hello everyone,
I'm getting ready to repair the floor and rockers of my 72 Jimmy. So far I think I'll need:
  • Outer rocker panels
  • Outer cab floor (about 4" in from face)
  • Inner rocker panel
  • Rocker boxes
  • Front cab supports
  • A pillar lower sections (about 12" up)
  • Kick panels
  • Lower bed section (just behind doors)
There are some small issues further in on the floor but it will be much cheaper to make the repair sections myself instead of buying the whole floor.
As far as I can tell, the rear rocker box closing panels look ok. They will be removed, cleaned, inspected, repainted and reinstalled. Do these usually need to be replaced?
Here is some pictures of the floor and underside of the body: Google drive
Anything else I should know? Am I missing any parts in the list?
Thanks!
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-16-2022, 02:55 PM   #2
Dan_P
Re: 72 Jimmy rust repairs
I just did something similar.
Also needed:
- B Pillar lower sections too
- internal rocker reinforcement assembly plate
- front fender lower reinforcing mounting plate
I used GMCPauls. A little more expensive but I wanted to cry once and pay for the 16ga steel. https://gmcpauls.com/Patch_Panels.htm
Dan_P is offline   Reply With Quote
Old 08-16-2022, 08:56 PM   #3
best view
Rust what rust we call that brand new out here lol
best view is offline   Reply With Quote
Old 08-17-2022, 06:06 AM   #4
87Skier
87Skier's Avatar
Haha, I can't imagine the nightmares you guys deal with.
Also needed:
I'm hoping I don't need to get into the B pillar at all. Probably just replace the fender mounting plate, it's cheap enough and in a common rust area. I think the inner rocker is included in the set from GMCpauls. I am going to order from there. Probably around $700 before shipping.
I'm really looking forward to having carpet in it. I've had it since 2013 and it's never had carpet or sill plates.
How long did it end up taking you to do both sides?
Old 08-17-2022, 08:28 AM   #5
best view
Mine came from Monterey cal needed both a and b pillars inner and outer rockers bottom of doors and rocker boxes both sides
Old 08-17-2022, 09:09 AM   #6
jaros44sr
jaros44sr's Avatar
Are your tetanus shots up to date? What kind of tools do you have? Take lots of pics for reference on reassembly...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
