Old 06-20-2018, 01:45 PM   #1
66-GMC
66 GMC K1000 front wheel hubs (Please)
Someone over torqued both front drums (all 3 bolts) and bent the wheel hubs. When I did a brake job the speed shop told me they couldn't turn the drums because they are warped (from being tightened down to the bent hubs).
I don't want to switch to late model power brakes because my truck came with PS/PB from the factory and it only has 61,000 miles on it so I want to keep it all original ...if I can find the hubs.
I've searched high and low for years and can't find these front wheel hubs (at a decent price). I've even asked a few people that sell disc brake conversion kits to give my number to people buying a kit so I could get their wheel hubs! No luck.
If anyone has front wheel hubs for a 1966 GMC, or a suggestion for finding them, please let me know. ~Johnie
66-GMC is offline   Reply With Quote
Old 06-20-2018, 02:08 PM   #2
gmcdeadhead
gmcdeadhead's Avatar
Re: 66 GMC K1000 front wheel hubs (Please)
are front drums you looking for ? 5 lug or 8 lug
gmcdeadhead is offline   Reply With Quote
Old 06-20-2018, 04:26 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I have a 66 Canadian built GMC 4WD frame and drivetrain I'm parting out. Wonder if there's any difference? Has the locking hubs.
Old 06-21-2018, 12:23 AM   #4
Captainfab
60-66 Nut
I have a '66 Chevy Dana 44 front differential that I will not be using. I would be willing to sell the hubs if the ones aerotruk63 offered don't work out.
Old 06-21-2018, 06:41 AM   #5
aerotruk63
aerotruk63's Avatar
I'm headed to Texas , therfore you might be better with the captains offer. Won't be cack for two weeks or so.
Old 06-21-2018, 11:42 AM   #6
61K10
61K10's Avatar
3 bolts? need a pic.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-21-2018, 01:44 PM   #7
66-GMC
I appreciate the support. thank you all!
It's a 6-lug, 2wd and the front has independent suspension (not straight axle). I've searched for an exploded view but haven't found one that shows the back of the wheel bearing hub where it's bent from all 3 bolts being over-torqued. I'll take it apart and take a photo this weekend.
Old 06-21-2018, 04:58 PM   #8
aerotruk63
aerotruk63's Avatar
K1000 would indicate a 4wd.
Were not on the same page for now.
Old 06-21-2018, 11:12 PM   #9
Captainfab
60-66 Nut
Yes agreed, a K1000 is a bit different than a C1000. And I'm not understanding the whole "it's bent from all 3 bolts being over-torqued"
Old 06-24-2018, 12:16 PM   #10
jdl71
jdl71's Avatar
Do you need hubs or drums? 6 lug drums should be readily available.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 06-25-2018, 06:16 PM   #11
66-GMC
Re: 66 GMC C1000 front wheel hubs (Please)
I'm the 2nd owner of my '66 GMC (since 1998). I never knew the model and mistakenly said it was a K1000. My first vehicle was a '66 Chevy C10 shortbed but I never knew its GMC counterpart. I must have gotten the K1000 from Rock Auto when ordering parts.
The reason I mentioned it's history is to explain the how problem could be a factory caused issue on such an old truck (but only 61,000 miles though). It was the factory rivets, not over tightened bolts, that caused the wheel hubs to warp (bend). They were so overdone that they bent the wheel bearing hub (yes, the same thick part of the wheel hub that the 6 lug studs are attached which sounds a little crazy I know). It had to have been done by the factory because once the rivets are removed, as you all know, there's no reason to ever redo them. I always wondered why the wheels got so hot and why I was going through shoes so quickly. When I tried to have the drums turned and found out they couldn't because they were warped, everything became crystal clear.
Unable to find replacement wheel hubs, my truck has been left to sit with only occasional attention to keep it maintained over the past 15 years or so and that's why my memory was a little hazy.
Anyways, that's where it sits today and why I need wheel bearing hubs for both front wheels. I already have new drums, shoes and everything else. I didn't have time to take it apart to take photos but I'll do it as soon as I can ...if for no other reason than to show how bizarre it is!
Old 06-25-2018, 06:23 PM   #12
aerotruk63
aerotruk63's Avatar
Now were on the same page. Sorry can't help you personally.
Old 06-25-2018, 08:09 PM   #13
jdl71
jdl71's Avatar
So you need 2 front hubs for a 66 1/2ton gmc two wheel drive, correct?
Psalm 23
64 C10
66 K20
Old 06-25-2018, 11:58 PM   #14
Captainfab
60-66 Nut
'63-'70 hubs will be the same. I'll take a look and see what I can come up with.
Old 06-26-2018, 10:47 AM   #15
66-GMC
Thanks. ~Johnie
Old 06-26-2018, 10:43 AM   #16
66-GMC
Correct. I should have described it as you did here. It's also a fleetside longbed but I think they're the same wheel bearing hubs on all 2wd models.~Johnie
Old 06-26-2018, 12:22 AM   #17
padresag
i have a set of hubs and spindles 1964 but for k10 and i didn't read the whole thread first
ron
padresag is offline   Reply With Quote
Old 06-26-2018, 10:50 AM   #18
66-GMC
ron
Thanks for checking. If anyone reading this has Admin permissions I'd appreciate it if you can change the original thread title from K1000 to C1000. ~Johnie
Old 06-26-2018, 06:16 PM   #19
aerotruk63
aerotruk63's Avatar
I don't think they used letters with GMC just numbers .
Old 06-26-2018, 11:35 PM   #20
Captainfab
60-66 Nut
I have a pair that I can pull off in a few days. I would like $65.00 plus shipping for the pair.
Old 07-05-2018, 02:33 PM   #21
66-GMC
Thanks! Hope you had a great 4th of July! Should I order new races and bearings for them? Lugs? ~Johnie
Old 07-06-2018, 12:19 AM   #22
Captainfab
60-66 Nut
The 4th was just another day of work for me. I haven't bothered to pull those hubs off since you did not say whether you wanted them or not. Yes I would go with new bearings and seals. If you do want those hubs you need to let me know.
1966 gmc, disk brake conversion, wheel bearing hub
