12-19-2017, 12:16 PM | #1 |
To seal or not the intake to head coolant ports?
I am installing my intake on a new 350 crate engine. Should I use a sealer around the coolant ports? There was sealer on my old engine. If so, what sealer is recommended?
I am also reading that just about everyone junks the front and rear rubber gaskets for the intake and uses a silicon sealer. Is that recommended, and which sealer for that? |
12-19-2017, 12:38 PM | #2 |
Re: To seal or not the intake to head coolant ports?
The front and rear gaskets are prone to leak. Use silicone and be sure to lap up over the edges of the head gaskets. This is pretty much leak proof. Did not recall using any type of sealer around the coolant ports....but I have slept since then!
12-19-2017, 01:01 PM | #3 |
On the coolant ports, I have always used old school brush-on Permatex. Just put a thin coat on each side of the gasket.
12-19-2017, 03:05 PM | #4 | |
Brown Aviation Form-A-Gasket specifically.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
12-19-2017, 01:08 PM | #5 |
I put sealant on the water ports all the time when I do intakes. I use the Right Stuff from Permatex which you can get from any parts store. Reminds me of a cheese wiz can..
12-19-2017, 02:04 PM | #6 |
Thanks for the replies.
12-19-2017, 03:22 PM | #7 |
Yep, the Aviation gasket stuff is great. Best thing in the world for cork gaskets also.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-19-2017, 05:25 PM | #8 |
And to protect the bottom of your intake port gaskets from leaking due to hot oil, you can put a light skin on the bottom edge on both sides. Old racers trick.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-19-2017, 05:59 PM | #9 |
I did an intake 3 years ago by using permatex (black?) around the water jackets (both sides - just a light skim coat) then a thick 1/4"+ bead on the front and back. Let it get a tacky "skin" on it. I then torque in sequence to half spec the first time (should be available somewhere online, usually from the center out), then full the second time. Let it sit overnight and do it again the next day. I pulled that intake off recently to replace it with a 4 barrel and not only did it pop off cleanly, but the gaskets looked new still. Made putting the 4 barrel on much easier.
*ALSO* TEST FIT everything. Couple problems I've run into (on Ford and GM) - The new intake had tabs that hit my valve covers (on SBC). WAY easier to grind off when it's off the motor. An aftermarket intake was "taller" than my stock one so the intake bolts were too short (on a SBF). Distributor hit (again, on a SBF). So, just dry fit everything and look for problems.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
