07-12-2009, 03:56 PM | #1 |
Check it out
SO WHAT DO YOU THINK ?
I JUST RECENTLY FINISHED THE 2 LINK, MOUNTED THE 31GAL TANK FOR MORE CLEARENCE, AND ROUGHED IN THE BODY WORK ENOUGH FOR ITS FIRST COAT OF PRIMER. BEFORE... AFTER... ANYONE HAVE ANY IDEAS ON HOW TO GET THE FRONT A LITTLE LOWER?
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:10 AM. Reason: updated pictures |
07-12-2009, 08:58 PM | #2 |
its just $$$$$
Re: Check it out
Dropmember
07-12-2009, 09:27 PM | #3 |
Re: Check it out
Yea I know i checked it out but i just got laid off and unemployment doesn't pay that good. I just might have to wait for next years tax returns.
Nice Blazer by the way!
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow |
07-12-2009, 09:36 PM | #4 |
its just $$$$$
Re: Check it out
you could always do a Z
07-12-2009, 09:59 PM | #5 |
Re: Check it out
looks good man i would do the crossmember
07-12-2009, 10:17 PM | #6 |
Happy to be here
Re: Check it out
What do you have in front now?
07-12-2009, 10:59 PM | #7 |
Re: Check it out
Thanks Guys
3" DJM spindle w/ Firestone 2600 bags w/ plates up top and cups down below. I was thinking about cutting the cups just a little to maybe get an inch. Would control arms help?
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:17 AM. Reason: updated pictures |
07-12-2009, 11:07 PM | #8 |
its just $$$$$
Re: Check it out
oh yeah, cut the cups for sure!
07-12-2009, 11:45 PM | #9 |
my short bus
Re: Check it out
remove you cups and cut in some 8" pipe
I used a 2.5" piece lays on crossmember and misses heater box by .5" I also have 3" belltec spindles with a upper bag plate like your I'm running 255/70/15 on a 8" rallie on my burb I went from this to this hope this helps cost me $150 for the metal and having it welded in
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
07-13-2009, 12:40 AM | #10 | |
Re: Check it out
I wouldn't have to worry about heater box
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:20 AM. |
07-13-2009, 08:11 AM | #11 |
Low & Fast!
Re: Check it out
Looks good! Cut 1" off, that is what I did but do not cut any more then that you could rub your bags..
07-13-2009, 06:42 PM | #12 | |
Re: Check it out
By the way man love yor blazer mine will also be BLACK, that was the original color but my interior will be RED
07-13-2009, 12:03 AM | #13 |
Re: Check it out
How much do you think I should cut off?
Do you know of anyone who has used plates on the lower control arms like these do you think these would help?
07-15-2009, 08:31 AM | #14 |
Arrived on a Pale Horse
Re: Check it out
Doesn't that diff need a panhard bar? How will it keep from going side to side?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
07-16-2009, 11:45 AM | #15 |
Re: Check it out
I need to mock up the motor and trans first to get the pinion angle correct.
07-15-2009, 09:42 AM | #16 |
Re: Check it out
could u post some pics of the 2 link,thanks
07-15-2009, 10:02 PM | #17 |
Re: Check it out
Nice job, I look forward to watching your progress. I'm just about to smooth my firewall, hopefully this weekend.
Ryan 84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
07-16-2009, 11:46 AM | #18 |
Re: Check it out
It's a lot of work they wernt very straight from the factory to begin with, Good Luck!
07-16-2009, 03:59 PM | #19 |
Re: Check it out
made the bars from 1.5"O.D x .25wall DOM (Expensive) Bag brackets are from suicidedoors
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:25 AM. Reason: update pictures |
07-16-2009, 09:08 PM | #20 |
its just $$$$$
Re: Check it out
do those bars have a pivot on each end?
07-17-2009, 12:57 AM | #21 |
Re: Check it out
yes in the front of the bar it has urethane replacment bushings, or i could use stock replacement. The rear of the bar has large heim joint, i wanted to be able to adjust it if needed. I still haven't installed the suicidedoors pan hard bar. I tested the system and it travels fine without any binding
07-17-2009, 09:58 AM | #22 |
Low & Fast!
Re: Check it out
I like that, looks simple. How are you going to run your shocks?
07-20-2009, 03:46 PM | #23 | |
its just $$$$$
Re: Check it out
06-22-2010, 01:39 PM | #24 |
Re: Check it out
rear set up looks great, nice work!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
06-23-2010, 10:51 AM | #25 |
Re: Check it out
Nice progress!
