10-01-2002, 09:29 PM | #1 |
47-54 body on 69 frame???
I have a 69 chev longbed . I would like to know if any fellow members have ever cut a 69 frame and made it work out with a 47-54 body or if it would be better to just graft the front clip and rear suspension to a 47-54 frame. Regards
10-02-2002, 09:41 AM | #2 |
Fabricate till you "puke"
I have seen that swap ,but the track width is a little wide for the truck. Check out the guys @ http://www.fatmanfab.com/ for a mustangII setup to fit the truck. Altho not cheap,I have seen this setup under many trucks & cars,& it seems to work pretty well. Good luck......crazy AL
10-02-2002, 06:56 PM | #3 |
frame swap
Thanks Crazy Longhorn. Not bragging but having built several race cars and worked on a Nascar Winston Cup Car back in the 70's to about 86 I think that it would only be a matter of looking up track dimensions , taking alot of measurements and then tying a front clip together with 2x3 tubing and fabing a rear clip. I like to all the work myself , it just makes it more interesting and fun. Thanks for the reply and any others that would like to reply would be helpful. Regards
10-02-2002, 09:57 PM | #4 |
If you are into chassis work, you are way ahead of the game! I have also seen Volarie suspension under some of the early trucks.......it looked like a bit of fab work, but may be worth a look. I have cut & spliced frames,& done quit a little fab work.......but when it comes to suspension, i tend to work with what the factory gave me. At any rate, good luck & have fun ,that is what hottrodin is all about!
