Wheelbase lengths
I'm shopping for a 64-66 fleetside or a 64-66 suburban. I know the two w'base dims for the fleetside is either 115" or 127". What I have not been able to find is the w'base for suburban. Anybody got a source for the suburban w'base dimensions? Thanks!
#2 | |
Re: Wheelbase lengths
ron |
I would have thought that the subbie w'base would have been 127 or more. If the subbie has a w'base of just 115" then that must mean that I could use a swb pick up truck frame for the frame on the subbie, changing body mounts of course. Right?
#4 | |
there are 3 different sets of frame brackets for body mounting that the pickup doesn't have and there is the rear frame extension. ron |
everything you want to know:
http://gmheritagecenter.com/gm-herit...tion-kits.html |
Ron,
thanks for this info, I just picked up a 65 Burb and was thinking of moving the body over to a 71-72 SWB truck for the disc brake and 5 lug but with the added body mounts I will stay with stock frame. |
#7 | |
The front assembly/crossmember will bolt on to the '65 frame then some 5-bolt rear axles an you're all set. Sounds easier than cutting down the '71 frame 2" and adding the correct body mounts.
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
