Roto Reuter thats the name...
![]() Join Date: Feb 2010
Need help with front leaf spring plate orientation
I'm swapping in a mid 80's Dana-44 front axle in place of my drum brake axle. The newer axle has a 3" tube versus the 2.75" tube on my original axle. Because of this I needed different U-bolt spring plates to accommodate 3" U-bolts. The spring plates I have are OEM versions that have the threaded holes for a sway bar.
I'm trying to determine the orientation of the driver side plate. The passenger side is pretty much self-explanatory due to the larger diameter U-bolt on that side. What I need to know is on the driver side, does the threaded hole for the sway bar face the outside or inside? I would think it would face the outside (picture #2) to match the passenger side. If that's the case, it orients the raised blocks on top of the plates in different positions. Thanks for your help. Do the leaf spring plates go like this? Or do they go like this?
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
All about them K’s
![]() Join Date: Jun 2014
Re: Need help with front leaf spring plate orientation
This is a late 80’s K30. You can see the driver side sway bar bolt faces the engine and the passenger side sway bar bolt faces the passenger tire.
My 57 is on a late 80’s blazer frame and it’s the same orientation.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Interesting. Thanks for chiming in. I'll see if anyone else comments. Thanks again.
All about them K’s
Yep no problem. I went out and snapped one of my 57 too.
same way on my truck.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
![]() ![]() Join Date: May 2015
91 burb is the same also...I assume its on the inside on drivers side to clear the steering/pitman arm
![]() Join Date: Mar 2003
Thanks guys. Greatly appreciated.
So next question is can I install a sway bar on my 70 K10? Originally I was not planning on it, but the leaf spring plates are set up for one. If so, what else would I need to do so? What year sway bar do I look for?
All about them K’s
I believe In order to run the GM bar you’ve got to swap to a square body engine crossmember setup for the sway bar.
Ah, OK. Well that's not going to happen. I swapped my front cross member to the Tilden Motorsports LS one for my swap.
I'm sure with a little ingenuity something can be fabricated to work. I'd lay a square body bar in there loosely bolted to the plates and hold it up to the frame with a bungee cord and see what can be done
