09-24-2022, 11:31 AM | #1 |
Wilwood master cylinder
Have 72 gm c10 2wd looking at replacing the master cylinder. Does anyone know the bore size?
09-24-2022, 12:01 PM | #2 |
Re: Wilwood master cylinder
I have been running a manual Wilwood master with 7/8” bore for 4 or 5 years now. I’m happy with it.
A bit more pedal effort than with a booster, but the previous engine didn’t make enough vacuum to operate the booster. Some day maybe hydro boost and bigger brakes all around. But then I will need larger wheels and then tires …….and….
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
09-24-2022, 01:00 PM | #3 |
Forgot to add that my truck is also a 72 C10 stock front disk/ rear drum at this time.
Couple pics
09-24-2022, 03:28 PM | #4 |
If you already have power brakes it should be 1-1/8" I believe.
72 C10 lwb fleetside -stock 350/350 combo |
09-24-2022, 06:10 PM | #5 |
I installed a 1 1/8 with a booster on a truck that is ls swapped but has a pretty mild cam. I ended up switching to the 1 inch bore because it took more pedal pressure than I liked to stop.
09-24-2022, 11:03 PM | #6 |
ok. thanks
