Old 03-28-2011, 01:54 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
6.0l LQ4 to old school tranny
I want to make sure I have this right:
2004 LQ4(not sure what trans was behind it, I forgot to ask) I am posting a pic so that maybe it will help with what I need to know:
I need to adapt my th350 to the 6.0 If it did in fact come with a 4l80e then I should be good as far as spacer and bolts correct? If not then I need to get the spacer and bolts correct? Then I need the flat flexplate and drill holes for the th350 TC? When I go to mark the holes in order to drill new ones, does it matter where on the flexpalte they are drilled? Should there be a certain distance from the factory holes?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-28-2011, 03:56 AM   #2
softballnrd27
Re: 6.0l LQ4 to old school tranny
For the VSS will this one work with the stock computer? I am going to run Autometer procomp gauges and this is the recommended one for GM.
http://www.summitracing.com/parts/ATM-5291/
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-28-2011, 09:25 AM   #3
Shon
Need to determine what flexplate is on the motor. if it has a spacer already then you will just have to drill holes for the TC. If it doesnt have a spacer then you will want a crank spacer.
link to just the spacer pictured above
If you want all new stuff I ship these out:
TCI Flexplate and spacer
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-08-2019, 10:53 PM   #4
Andyking1203
Is the second link still available so many years later?
Andyking1203 is offline   Reply With Quote
Old 02-09-2019, 08:35 AM   #5
Shon
HerronPerformance is gone. Was mine that’s how I know. But the TCI spacer is still available from many places.
Old 03-28-2011, 12:02 PM   #6
softballnrd27
How much for that kit? I am guessing it is already drilled for th350 pattern.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-28-2011, 12:07 PM   #7
softballnrd27
I guess i could have just clicked on the link.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-28-2011, 03:42 PM   #8
shortbed70
shortbed70's Avatar
Do these flexplates work with 700's and th 400's also?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-28-2011, 03:45 PM   #9
Shon
We use them on TH350/400s and I dont see why they would not work with a 700R4, the bolt pattern for the TC is the same.
Old 03-29-2011, 10:53 AM   #10
jkade
jkade's Avatar
http://www.gmpartsdirect.com/
GM PART # 12621399 $44.42
That has the flexplate, spacer, and bolts. All you will have to do is do a little grinding with a die grinder on the new flexplate to match you converter. The bolt holes are close but you have to open them up a little. Working fine on my LQ9/th400 and you won't beat the price!!!
You can see here what I am talking about.
jkade is offline   Reply With Quote
Old 03-29-2011, 10:59 AM   #11
Shon
How much is shipping from there? LOL
If you want that set up let me know, I will see if I can ship it to you cheaper than GMPD.
Old 03-29-2011, 12:20 PM   #12
jkade
jkade's Avatar
It was around $10 for shipping. Heck of a deal for plate, spacer, and bolts IMO since most places want that for just the spacer.
Old 03-29-2011, 02:43 PM   #13
67shortie
Green club
67shortie's Avatar
My engine came off of a 4L80 so the flexplate had the correct adapter already there so all I had to do is elongate the converter holes to mount the 700 to it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-29-2011, 03:08 PM   #14
clinebarger
You should not have to mess with the converter bolt holes on a "4L80E" flexplate
Is that what you got from GM parts direct? If so, Its wrong, Looks like a 4L60E flexplate. It should look like this, Notice the 6 converter bolt holes.
clinebarger is offline   Reply With Quote
Old 04-01-2011, 03:49 PM   #15
clinebarger
I was wrong, You do have to open up the holes a little, I dont know why GM would change that on the 4L80E from the early ones.
Old 04-04-2011, 11:04 AM   #16
jkade
jkade's Avatar
That was a flexplate I had laying around just to see how far the holes were off. I used the one in the kit. The one in the pic will work as it was a dished plate as well but I did not have the spacer.
Old 02-09-2019, 12:01 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^Holy crap dude I haven't seen your username here in a while!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
