99 Suburban 2WD 1500 series - SQUEAKS
Not applying the brakes just turning corners or dips on the highway....it squeaks! For sure from the passenger side.
Any ideas what it could be? Can someone point out all the grease fitting locations? I gotta grease gun. Also....could it be suspension parts (shocks/struts springs) Thanks guys. |
Re: 99 Suburban 2WD 1500 series - SQUEAKS
I would guess ball joints.
laying low
![]() Join Date: Mar 2001
Yes mostly likely the lower ball joints. The zerk fitting should be on the back side of the ball joint pointing to the rear of the truck. With grease and dirt buildup it can be difficult to find.
![]() Join Date: Jan 2003
The front end should have 11 grease zerks:
1. Pass Upper Ball Joint 2. Pass Lower Ball Joint 3. Pass Outer Tie Rod 4. Pass Inner Tie Rod 5. Idler Arm to Center Link 6. Idler Arm Bracket (next to lower radiator hose) 7. Pitman Arm to Center Link 8. Driver Inner Tie Rod 9. Driver Outer Tie Rod 10. Driver Lower Ball Joint 11. Driver Upper Ball Joint Also check the drive shaft U-Joints, if they have been replaced, they may have grease fittings.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
#5 | |
![]() Join Date: Sep 2005
![]() most ly your lower ball joints are empty on greece and it it been squeaking for a while probley going to need to be replaced
