56 - autocross
HELP Master Cylinder Frame Install 56
I bought a master cylinder that mounts to the frame rail but uses the stock pedal and some of the mounting hardware. Unfortunately I had taken all that stuff off before I went down this road (doh). I need pictures of what a stock master looks like and a completed one as well. Pictures of any type would be appreciated and i can seem to find them on the site. I have the directions (for new install) and the original parts that have been removed (in a big pile with other frame junk) but I need a starting point.
Elev8r Man
Re: HELP Master Cylinder Frame Install 56
I will try to get one for you tomm
I can get you a better picture tommorrow.
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
56 - autocross
Thanks for the pictures. I appreciate it and appreciate any other pictures you may have. People on this web site are GREAT!
anyone else have any pic's of a dual m/c on a task force truck? trying to do a simple upgrade for safety sake.
Yellow truck club
try this
from TCI http://www.totalcostinvolved.com/ins...m?ManualID=374 or these from No Limit http://nolimit.net/Instructions/Pwrbrkkit.pdf http://nolimit.net/Instructions/PBC55.pdf
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Here is what I did. In 85 I build a bracket to use a 74 truck dual MC with the 4wd axles. I wanted to use the stock pedal and mounting location. This time I added onto the bracket for a booster which moved the MC. In the second photo you can see the new bracket over the original. The shaft between the pedal and booster is made up of 1/2" EMT with nut welded on one end and 1/8" stock with hole welded into a slit on the other. This is based on TCI and others aftermarket kits but with heavier stock so you don't need the cross braces and the booster support matches the booste radius.
Orrie
Keeping an eye on this as I am planning the same deal for my truck. How did you (or do you) access the reserivor ?? |
I made this, more detail in my build thread at http://67-72chevytrucks.com/vboard/s...&postcount=135
I set my seats up so the factory tilt forward will work for access under them. They are Yukon 3rd row seats.
#10 | |
Yellow truck club
Hey look there I am now ...
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 08-28-2010 at 10:28 PM. |
That's a good one, Brian. LMAO.....
I just installed that setup on my truck. They sell an access door that you weld in, or you could make your own like Orrie did, but if you keep the original seat Brian's method seems to be the only way. |
Elev8r Man
Or you can try this kit that I found a while back, gonna use it on my 58 fleetside. Just trying to find a place to mount the reservoir. I am getting it from this site.I don't wanna lay on my back with a mirror or tube, lol.http://www.classicperform.com/Store/...rucks/RRCK.htm
56 - autocross
There is a cast housing "thing" that is riveted to the frame in front of the cab mount next to the brake system bracket. It looks like it supports a shaft of some type. What is this for? Part of the brake system. The pictures above show it (barely) but do not show if there is any brake involvement.
hotrod
Your not talking about the clutch petal pivot point are you ??? I have some pictures but they are not very detailed. |
#15 |
Here are a couple of shots I found. I am pretty sure that is the clutch pivot casting you are talking about.
