Need Electrical Help
I have a few issues with my truck.
*First off my dome light doesn't work I have replaced the fuse and replaced the bulb with a led one. Visually inspected the wire and don't see and cuts in it. *Second my cigarette lighter sparks a lot when I try to plug it into the correct place on the fuse box it sparks a lot, Then when I put the cigarette lighter in will kick it out almost instantly. *And my turn signals dont work, not sure where to start on them. Any tips or solutions would be appreciated. |
#2 | |
Re: Need Electrical Help
I would also make sure your cab is well grounded as a poor ground could be causing all of your issues. Wiring can be a nightmare but if you stick to it and try the simplest solutions first you can usually trace down your problem.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
Oh the wiring was a mess getting it fine tuned but thought about removing the lighter assembly and trying to clean the inside of it and try it. And does it matter if the little light is connected to the cigarette lighter. The dome light did work till I broke it and replaced the the dome lens and broke the bulb and replaced it and turned my light switch nothing.
Well flipped my led bulb in my dome light and it works. Didnt know that leds were directional but it fixed that problem. Now need to track down the issue with my turn signals and cigarette lighter. Thinking I may have the wrong amp glass fuses installed so gonna start there and see if that does anything.
Yes led bulbs are picky. It has do do with their design.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
