SWB 4x4 Collector
![]() Join Date: Jun 2001
B pillar to floor pic
Guys I am needing help figuring out what the b pillar to cab floor joint looks like as mine is ate up. Thanks Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
What?
Re: B pillar to floor pic
Which side?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Member #1049
Here is picture of a "sorta" rusty pickup OEM one
Member #1049
Here are "sorta" rusty burb ones
SWB 4x4 Collector
Thanks livrat .....I also need to see the inside...how it meets the floor. A view from inside the cab looking down at the pillar. Trevor
Member #1049
I'll try to get out to my parts burb tomorrow and take a couple pictures of the inside for you
SWB 4x4 Collector
Much appreciated Livrat! Just can't figure out if it overlaps the floor on the inside, goes under the floor, or doesn't even weld to the floor. The bottom inch is gone. Trevor
![]() Join Date: Jul 2010
Went out and snapped a few. I just finished putting in both front outer rockers, my inner rockers were just fine. I cleaned up the 'channel' where the B pillar and floor met and put in some evercoat 2k seam sealer. I did the same to the drivers side. It just seemed like a good place for future corrosion so I nipped it in the bud Andy. The black is POR 15.
In the third pic, you can see my addition of a door switch. I put one in the third door pillar and one on the right barn door in the back. Regular sized door courtesy switches used on front doors are too big, so I used ones from a vintage VW beetle.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Member #1049
here are a couple, the pillar actually sits on top and curves over the side and bolts to the floor support
SWB 4x4 Collector
Thanks again, I appreciate it. Trevor
