10-03-2019, 09:39 AM | #1 |
wheel Stud
Can anyone help me out. I need to change my wheel studs for longer ones and I am not sure what is the correct size for my 1969 c10 step side I would like to get some that is 3" long any help would be great
Thanks, |
10-04-2019, 10:12 AM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: wheel Stud
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-04-2019, 11:02 AM | #3 |
Re: wheel Stud
thanks for the help
10-04-2019, 01:49 PM | #4 |
Re: wheel Stud
I don't think the factory size on 1969 6 lug is 1/2-20.... I think it is 7/16 but you can drill them out for the 1/2-20....
10-04-2019, 02:18 PM | #5 |
Re: wheel Stud
It is 5 lugs
10-04-2019, 04:17 PM | #6 |
Re: wheel Stud
I would remove one and take it with me to the parts store to be sure I got the correct ones. There are quite a few different spline configurations out there.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-04-2019, 06:05 PM | #7 |
Re: wheel Stud
I can do that thanks everyone
10-04-2019, 06:15 PM | #8 | |
Moderator
Re: wheel Stud
https://www.jegs.com/i/Moser-Enginee.../8050/10002/-1
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-04-2019, 07:55 PM | #9 |
Re: wheel Stud
Ok , hoping some one can help me .
I need longer studs , for new aluminum wheels. My 68 K1500 , has. 7/16 x 20 studs . My question is how do I determine the spline diameter ? I think they at .560. But I am not sure and need this size to order proper studs . |
11-05-2019, 12:38 AM | #10 |
Re: wheel Stud
Pound one out and measure with a dial caliper. Measure both the stock stud and the hole. There should be a slight difference between the two. There is an acceptable range of a difference between the stud and hole for the proper press fit.
I would measure the front and back to see if they are the same. My rear's were a smaller knurl than the front, but I had aftermarket front brake rotors. If you can find half inch threaded studs with the right sized knurl for the hole you have then it would be a good upgrade. https://tech.arp-bolts.com/wheel-stud-fit.php Also, depending on what you have for wheel thickness and lug nuts, closed end lug nuts specifically. Dont be surprised if you have to cut the studs to a custom length. Last edited by sprint_9; 11-05-2019 at 12:47 AM. |
11-05-2019, 06:13 PM | #11 |
Re: wheel Stud
I called dorman direct , they had all the info I needed . Saves a lot of guessing. Got the part number for my front hub studs
11-06-2019, 03:55 PM | #12 |
Re: wheel Stud
Can you share, need to replace the front studs on my 71 5-lug but do not know the knurl size. It is a driver so I can't knock them out and measure without replacements ready to go.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
11-06-2019, 04:14 PM | #13 |
Re: wheel Stud
Go on line , get the dorman web site , they have a contact # . Call and go to tech dept. they also have an online chart , if you can locate you vehicle on it .
