Old 12-14-2009, 09:03 PM   #1
Becker67
Becker67's Avatar
can a pickup frame be used on a blazer
I seen a 72 blazer this weekend. I have been wanting to convert one to 2wd. I have a long bed frame and thinking it might be easy to shorten it to the length of a blazer. My qusetion is can it be done. Other then shorting it and changing body mounts is everyhting else the same.
Kevin
67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c
69 custom/10 swb 350/350 4/6 drop tach,tilt
71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning
96 gmc swb
Becker67 is offline   Reply With Quote
Old 12-14-2009, 09:06 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: can a pickup frame be used on a blazer
If you have a pickup frame and a Blazer frame, it would be easier to swap the 2wd stuff to the Blazer frame. Using a PU frame would require shortening the frame and fabricating body mounts.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-14-2009, 09:16 PM   #3
1sik52
This question has come up at least 5 times in the past 2 months!
1sik52 is offline   Reply With Quote
Old 12-14-2009, 09:30 PM   #4
turp mcspray
turp mcspray's Avatar
I don't have any details for you, but several years ago a friend of mine shortened shortbox 2wd frame for his blazer. It wasn't very difficult.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-14-2009, 10:35 PM   #5
cvalcore
cvalcore's Avatar
what we need is someone who will do one so people will no if it is truly possible and can be done every one on here has a lot of different opinions on if it will work or not but no defendant answers. i would kinda be interested in it also if done right it would look like a factory 2wd.
cvalcore is offline   Reply With Quote
Old 12-15-2009, 12:12 PM   #6
turp mcspray
When my friend did his, he shortened the frame by the difference in wheelbase, and added the rear blazer mounts from his blazer frame. I did see it, so I know it can be done and isn't extremely difficult. I'm sure someone on here must have done it as well.
Turp Mcspray
Old 09-14-2018, 03:42 PM   #7
clay og
I am trying to do the same thing.I have a 71 4x4 jimmy that would be nicer if it was riding smooth and 2wd. I know the frames can be shortened cause I have done a lwb to swb but don’t know if body mounts line up if you shorten a long frame to a jimmy.I don’t want to violate the stock frame in case I feel like making it 4x4 again. I want to be able to just sit the body on and go either way.
clay og is offline   Reply With Quote
Old 09-15-2018, 03:51 AM   #8
YBNORML
YBNORML's Avatar
Hopefully turp will chime in again. I'm pretty sure he ended up shortening at 3/4 ton longbox frame down for a Blazer.
That being said, I have a factory 2wd Blazer and before I modified it to my liking, it still rode like crap
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-15-2018, 02:54 PM   #9
clay og
It’s mostly not about the ride quality for me. In 4wd form it dosent ride bad. I just want to have a 2wd and 4wd version. Since I have 2 I might as well. Located a frame now just have to measure and see how body mounts line up.
Old 09-15-2018, 11:16 PM   #10
1rippen6
I just scrapped 2 if you need some extra body mounts.
1rippen6 is offline   Reply With Quote
Old 09-18-2018, 06:22 AM   #11
ta2ed
My son and I are in the process of doing this exact swap right now, 72 k5 to a 69-72 swb frame. Shortened the frame 11” set the body on everything lines up with the exception of 1 missing mount on each side.
ta2ed is offline   Reply With Quote
Old 09-18-2018, 09:09 PM   #12
Gillnetter
Gillnetter's Avatar
Where did you cut the frame? Any pics?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 09-19-2018, 05:54 AM   #13
ta2ed
We cut the frame under what would have been the cab floor behind front cab mounts, I don’t know how to post a pic up on here but if you want to message me I can either email or text you a couple pictures. Was a pretty good job to do. It just takes a little patience which is hard for me lol
Old 09-18-2018, 06:27 AM   #14
ta2ed
My son and I are doing this exact swap at the present time. Shortened a swb frame 11” mounts line up other than 1 that the pick up frame didn’t have. We knocked the rivets off the k5 frame and used those on the new frame. No other issues....so far.
Old 09-18-2018, 05:52 PM   #15
preciador6
I think the 65-72 snub nose P10 is the same as a blazer frame.
preciador6 is offline   Reply With Quote
Old 09-19-2018, 09:29 AM   #16
Ta2edjr
http://67-72chevytrucks.com/vboard/s...d.php?t=769907
Ta2edjr is offline   Reply With Quote
