03-12-2009, 12:44 PM | #1 |
Noobie McNoobster
Replacing wheel bearings
I just picked up a 1990 V2500 suburban this week with 243000 miles, I want to replace all the wheel bearings, is there anything I need to know (e.g. specail tools and or parts or tricks)? Thanks !!
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
03-15-2009, 12:54 PM | #2 |
Old Skool Club
Re: Replacing wheel bearings
One thing I like is a tool that allows you to grease the bearings with a grease gun. It's a couple of conical pieces that you place the bearing between, and then screw together. The threaded part has a Zerk fitting on one end and you grease the bearing through that fitting. It's messy, but so is putting the grease in the palm of your hand and working it into the bearing.
Aside from that, most of the irksome stuff I've seen involves the bearing races that are scored and/or hard to remove. Don't forget the seals that go into the backside of the rotor.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-15-2009, 12:59 PM | #3 |
What stile axel do you have? Are there bolts holding the axel in?
03-15-2009, 08:00 PM | #4 |
Also, if you intend to put new rotors/hub on, the races are already installed. I learned this the paranoid way. lol I hear getting old races out can be a hassle though, and you need to replace the races (well I would). Good luck and get ready to get greasy!
If all men are created Equal* does that mean we are all artifical?
03-16-2009, 09:22 AM | #5 |
Noobie McNoobster
Yeah I figured this 'burb will require me to get all kinds of greasy, I spent 4 hours fixing thetilt wheel bolts in the column :-)
