04-04-2018, 04:31 PM | #1 |
Inside tire carrier
Can someone tell me what the max tire size an interior carrier on a 71 Blazer fit? I wanted to put a 12:50 33” on it if I will fit.
04-04-2018, 05:13 PM | #2 |
Re: Inside tire carrier
Don't know the answer. I'd assume probably since 31's fit on it, right?
I wonder if anyones moved it to the right and centered it behind the rear seat for more clearance. Could look cool. |
04-06-2018, 09:12 PM | #3 | |
I see two options to to address this; 1.Fabricate an extension to add to the top of the carrier might address this issue. I haven't tried it yet. 2. Or you could take the carrier apart at the weld, move the top half up an two inches, weld the top back on and it would look stock. The larger tire does not interfere with the CST side panel. It is a bigger tire than stock and will significantly obscure your the view from the rear view mirror. The 33 x 12.50 will fit but slight modifications should be made to ensure it is secure. To answer your question, it will physically fit, but modifications should be made for it to fit securely. A tire breaking loose inside the vehicle during a collosion could be fatal.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 04-07-2018 at 07:04 AM. |
04-07-2018, 12:09 AM | #4 |
I'm curious whether a 15x6 inch wheel with a 33x10.50 R15 tire will have any issues.
04-07-2018, 04:25 AM | #5 |
I have 33 on my 71 Blazer and they look good
04-07-2018, 10:28 AM | #6 |
I'm no tire pro, but that rim size seems a little skinny to me!
-Bruce 1971 K5 Blazer 4WD |
04-07-2018, 10:30 AM | #7 |
07-10-2018, 08:12 PM | #8 |
If I remember correctly, on my 71 I had only a 235 X 15. It was just for looks because I had an original tire cover. Had 31's on the truck. You can see how close the tire is to the side. I doubt if anything larger would fit if correctly bolted to the carrier.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-15-2018, 08:54 AM | #9 |
Anyone selling a spare tire carrier?
07-16-2018, 05:55 AM | #10 |
There was one for sale recently on ebay
1968 C10 SWB 400SBC with VN327 20's 1972 K5 Blazer 383SBC 2011 Cadillac CTSV |
07-16-2018, 07:22 AM | #11 |
Mine has the 10-16.5 option, and the spare fit easily.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
07-16-2018, 12:38 PM | #12 |
Mine came with the same option. did not try fitting a 33" 12.50 tire in there yet.
