sealed hydraulic clutch master and slave
So....
Anyone ever see or hear of someone converting the stock hydraulic clutch slave and master cylinder to a sealed pre bled system? I have a 1990 crew with an sm465 and hydraulic set up. Replaced the slave, master, and hose with new and have spent HOURS trying to bleed the setup (yes I have tried a power bleeder, traditional pump, hold, and bleed, and depressing the slave with the reservoir cap off). The slave and master are both reman parts. A came across a setup for an 02 Dodge that looks like it might work with some creative engineering on brackets to get the throw right. Thoughts? TIA
1990 GMC CC LWB 1958 Chevy 3/4 ton flat bed |
Re: sealed hydraulic clutch master and slave
It would seem a shame. I've bled my 87 a number of times with relative ease. With a second person, it took 5 or 10 minutes tops to get it fully bled out.
Pedal down, open bleeder, close bleeder, pedal up. Repeat half a dozen times, then top off the fluid, and check for fork movement with the bleeder closed. As soon as the fork begins to move a little, just pump the dickens out of the pedal and it should gain full functionality. Edit: I would propose that either the master or the slave is defective from the factory. They're both pretty cheap. Just buy a general rockauto set, and see if that makes a difference.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
I had to bleed mine with it all hooked up but out of the truck and holding the master upside down .
Found the aftermarket master had a bubble size dome inside the reservoir to master nipple . It would let a bubble sit inside and random suck in and out . Once i did this problem solved for years .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#4 | |
#5 | |
I fought with my hydro clutch for hours. Then I went to Napa and saw this. It literally bled the clutch in less than 2 minutes. Perfect firm pedal.
Only way to go. |
the best way to bleed a slave it to take it loose from the trans, and slowly push it in and out. it will move alot of fluid that way and it bleeds fairly quick. never had one that wouldn't bleed out that way unless something was bad.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#9 | |
Posted via Mobile Device |
That is how I have been trying the last few times. I get a pedal enough to barely disengage and shift and two days later I lose everything. So something is not sealing. Which sends me back to my original idea to be able to install a problem system.
