05-27-2013, 11:04 AM | #1 |
need 292 exh man gasket help
Looking for info on what kind of gasket to use on my 292 exhaust manifold. I replaced it once with one from napa, and it didn't last very long and im tired of the ticking. Need info on what to use. Maybe its warped. I need to get it off again and inspect it.
Are all the exhaust manifolds for the 6's the same? Mine has some cracks and am considering replacing it. |
05-27-2013, 12:45 PM | #2 |
Re: need 292 exh man gasket help
As far as I know trey are all interchangable, but not the same exactly. There may have been some different bolt mount differences for choke heat shields, trhottle kickdown etc. I do have one or two extra manifolds aroiund here that could use a good home, and I even have access to a surfacing machine to make the mounting surface flat for you if that would help. Lemme know...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
05-27-2013, 03:46 PM | #3 |
Do you know what engine size your extras came from?
07-04-2013, 03:46 AM | #4 |
I also had problems with my 292 and the exhaust. Just had the intake and exhaust manifold bolted together and then machined. got a new gasket and problem fixed. Don't forget to tap the bolt holes, shot them with air, then loc-tite.
79' c20 std cab 292 3speed granny - daily driver. 77' c30 std cab 454 th400 4.10 - fathers truck then mine. 95' ford bronco 302 4speed overdrive. 2002 mustang auto v6 - girlfriends daily driver. Debt just means that you had more fun than you're suppose to have |
07-04-2013, 01:39 PM | #5 |
I should have specified which gasket. I was talking about the gasket that is sandwiched between the intake and exhaust. I am wondering if the exhaust man. is warped and wont seal. I have some ideas. I have another 2 pc setup i think i will try to have surfaced. I am looking for which gasket material is best to use.
07-04-2013, 07:23 PM | #6 |
Try Remflex.com, I don't see the intake floor/exhaust-heat gasket BUT they have sheet pieces to cut your own custom shapes. Remflex are thick graphite impregnated gaskets.
I'm using one on the head to intake/exhaust.
292 + TKO500 |
07-04-2013, 08:59 PM | #7 |
When mine blew -used a flat file to dress the surfaces and make sure they were flat. I did chase all the threads - used loctite with a new gasket( stock type ) and coated both sides with ultra copper . I've used this stuff on headers before and had to beat them off with a hammer.
LMD |
