My blazer now has drums all around and I was looking to get discs in the front. I have axles from a 3/4 ton 77 chevy truck with discs in the front and 14bff in the back. My only question is can I find 8 hole 15" rims to fit my 33x12.5's. and the drums in the rear
1970 BLAZER STOCK 350 AND TH350 FIRST VEHICLE HAD FOR 10 YEARS STARTING REBUILD THIS YEAR ![]() |
SKINNY TIRES RULE!
You shouldn't have a problem finding the wheels. Just about every wheel dealer should be able to get wheels that fit. Some styles may need to be machined out to fit over the larger style hubs - but I'm not sure if that is relevant for the '77 axle. You'll probably have to move the spring perches.
Swapping disc brake setup from a '71 or '72 1/2 ton should be fairly easy too. Your '70 should have open knuckels. I think there are after market kits available too.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I've read that I shouldn't have to move the perches on any 3/4 ton axle from 69-78. Am I wrong.
SKINNY TIRES RULE!
I am probably wrong. I thought that the frames on the later modeles were wider. There are a ton of K5's with 3/4 and 1 ton axels, so it is definately possible.
Check out GMTrucks.org
The front axle bolts right up. I have a '76 dana 44 in the front of mine.
I don't think the 14 bolt does though. I think you have to move the spring perches. |
OBS guy
Go to Austink5.com - someone is making that conversion on that site on a daily basis. Also ColoradoK5.com.
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
You guys are right the front does but the 14bff doesn't, I just can't read
#8 | |
Too many is never enough!
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) Last edited by J.Lance; 02-25-2005 at 09:16 PM. |
