With the stock intake manifold or an Edelbrock performer and and HEI what air cleaners will or won't fit? I read that normal 14'' ones do not. I plan to swap to HEI soon and I need to know if I should order an air cleaner too.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Dec 2001
I'm getting ready to do this myself and would like to know also.
Dave ------------------ 68 C-10 Custom LWB 307 V8 Three-on-the-tree Lexington,NC davideowens@lexcominc.net
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Just Another Crazy Canuck
if you are swapping over to HEI you will need a air cleaner for HEI setup as the points style rubs on the cap for now I run mine without and air cleaner( I know I know what can I say I'm cheap) but will be getting one when I wswitch to q-jet
------------------ My CANADA includes BEAVER!!!!!!! [img]http://communities.msn.com/_Secure/0NwAzABASh!uohRSfISjhQyAQFlB*NewhOUaHR6bv*u3evbZdsgR9IvkX4X4GCQKh*KzIWBO9**DLq1ZpIJppCQ/Chevy_anim(1).gif[/img] ![]() burlinator2000@hotmail.com Richmond,B.C. [This message has been edited by Burlinator (edited March 21, 2002).]
1985 ![]() ![]() ![]() soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
its all about the +6 inches
Eldebrock has a round 14 inch raised airvleaner that will work with HEI. It is in the Signiture series.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
get an offset base for the air cleaner. Mr Gasket, Moroso, lots of those guys have them. It moves the air cleaner forward.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
got an hei with edelbrock manifold, sp2p (later to install a performer manifold) and carb (1406). i run a stock air cleaner (for now) with a 3-4 inch riser. it clears just fine. soon to get a k&n.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
Ya might have to get a spacer to put under the air cleaner so it will clear the HEI. I had to put one on mine.
72 Custom, 400SB,T400,PS,PB,AC Chesapeake, VA |
newly minted old timer
am i missing something? i have put hei in several trucks with stock air cleaners. never any trouble, didnt even think about it before
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
I've got one of those edelbroke pro flo 1000 series ones, their triangular with a kind of wire mesh on top, no clearance probs, it's cheap, re-usable and I like the looks, doesn't hide your entire engine. Just my 3 cents though
Jesse ------------------ Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft. 1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power. |
Strongman Garage
![]() Join Date: Apr 2000
those can catch on fire.....
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
SLICER AND DICIER
Yep! I seen 2 cars runnin that triangle air filter burn to the ground after it backfired
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
Young Gun wth Fast Inline
The raised air cleaners will possibly have hood clearence problems. With my 6 i have a 4 barrel and 14" air cleaner with 4 element. My hood barrly fits, but it works fine. Those edelbrock proflows, the foam will get sucked in to the carb after a little use. Thats my experience.
------------------ 67 Chevrolet LWB with rebuilt 292. 415 ft. lbs of torque, 4 speed, 3.73 Posi, straight and almost painted.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
I've got an HEI in my 402. I have the spacer on top of my Carter, and have a 14X3 K&N with no problem.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
SLICER AND DICIER
How ya like my spacer. [img]http://communities.msn.com/_Secure/0MgAAAGYQOIaXblyw3*eyO*MtDVLOV2sCVpWQv688nAx*lrrPLyehIxTjpMGREkZeopNVAaqx4bkCjRN537zDXg/TMP10.jpg[/img] Sorry had to do it. Oh and I have no problems clearing the HEI. hehe. The stock hood will actually close no problem even with all that stuffed in there, but I got a cowl hood anyway, just for the COOL factor. hehe. Later
#15 |
67-72 Addict!
Slick engine!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#16 |
67-72 Addict!
Neonlarry,
Try an oval lid. Works great!
#17 |
Strongman Garage
i have an HEI and ran the stock air cleaner with the stock 3-4" spacer in between it now i switched to edelbrock performer intake, and a edelbrock signature seris air cleaner (it seems light it has a SLIGHT drop base) it clears the HEI just fine but the base hit the electric choke on my Qjet so i used the stock 3-4" spacer but it would work PERFECT with a 1" spacer which edelbrock sells for 10 bucks....
oh anthor thing i just remember i have a 1" carb spacer which could make a diffrence ------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
#18 |
Strongman Garage
#19 |
Recovering Truck Driver
most aftermarket chrome air cleaners will fit, i have a 14" chrome cleaner on mine(no idea what brand, came with the pickup). If you're wanting a stock look, grab an hei cleaner from like a 75 pickup or something.
------------------ '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s 67 Cutlass convertible 330, 3spd stick 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
#20 |
computer illiterate
I have a edelbrock 14 inch air cleaner on mine and it fits fine.
72 2wd blazer 72 swb 4x4 |
#21 |
K&N 4" tall 14" dia
#22 |
Awww sh$@! really? I sure wouldn't want my truck to burn up. You would think a company like Edelbrok would figure for something like that happening and fix it. I liked that thing too!
#23 |
NSANE68.....I like that spacer!!!!!
http://community.webshots.com/user/hotrodhorn |
#24 |
![]() Join Date: Oct 2001
Heres mine,mooneyes and k&nAttachment Converted: "C:\Program Files\Internet Toolkit 4.2\download\MVC-007S.ZIP"
------------------ BIG ORANGE 1971 SUBURBAN 1970/90-Little Buck's Truck (ONE DAY) USED TRUCK PARTS 4 SALE
Things happen for a reason! |
#25 |
Here's mine;
![]() And the foam does catch fire. i seen one burn to the ground. The day I saw that, i ripped mine off and drove without untill I had the time to replace it with this one here. Oh, BTW, I have a flat hood and no problems. i even have a figher intake now. (performer RPM) ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
