Converting auto hub axle
So, the axles I picked up for my upgrade for 8-bolt, the front doesn't have hub to lock or unlock. Will I be able to convert the axle to manual hubs? Any ideas as to what that will cost? D44 for a 76 K20.
Re: Converting auto hub axle
You know that you can just swap hubs for 6 bolt to 8 bolt upgrade? I have a set with milemarker lockouts I can sell you.
I think that you can pull the auto hubs apart and install manuals as well though. |
It's easy to install locking hubs unless your new front axle is from a Dodge full time 4x4. If by chance it is a Dodge axle, it would probably be cheaper and easier to purchase a complete GM front axle assembly. My son has a Dodge that has a Chevy front axle in it. They are interchangable.
I got a set of Warn Premium hubs delivered to my door for a little less than $100....got lucky when I did a search on Google.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
mgross - i'm 6-lug drums, going to 8-lug disc.
jacobs - the axle i'm going to use is out of a 76 K20. Thanks for the input. |
Mile marker website says that you have to have a conversion kit for auto hubs. Are they auto hubs or is it a full-time 4WD truck. i guess there is a difference. Full-time 4wd needs an adapter for the T-case, not sure on the axle.
Pull the auto crap out and install Warn Prem. hubs.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
