Old 12-21-2006, 11:32 PM   #1
jlaird
jlaird's Avatar
Project: Bad Bagged '68.5
Thought I would post my progress pics on my '69. So far I have started the back half. Nothing too fancy. This is my first build. Next I need to finish the bridge which I got from Suicide doors, and then install the 4 link.
Got a question concerning pinion angle. Are there any special considerations when setting the angle with a two piece draftshaft? I was about to tack the bag brackets on the axle, but got thinking if my pinion angle was correct?
jlaird is offline   Reply With Quote
Old 12-21-2006, 11:42 PM   #2
FnLow69
FnLow69's Avatar
Re: progress pics
Oh snap, that looks awesome.
FnLow69 is offline   Reply With Quote
Old 12-21-2006, 11:54 PM   #3
steveo10
steveo10's Avatar
Re: progress pics
i think it is suppost to have a upward angle of like 3 or 4 degrees. if you got a suicide doors 4 link the bars should have threaded ends so if you are off a little you can just twist the ends until you get it where you want it. when i set my bars i put it at about middle of the adjustment so i can change it if i have to.
truck looks good so far.
steveo10 is offline   Reply With Quote
Old 12-22-2006, 12:35 AM   #4
abadsvt
abadsvt's Avatar
Re: progress pics
Yeah I installed mine rear end at a 2-3 deg upward angle at ride height. Also when you install the 4 link you want to install it at your estimated ride height. You want the 4 link bars to be paralle to the ground at ride height or pretty darn close. I imagine that you would want to install your bag brackets at ride height also. You pretty much setup everything at ride height. LOL, I said ride height a crap load of times (its been a long day). Anyways you definately are on the right track though cause your truck is looks sweet! Good luck!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-22-2006, 02:20 AM   #5
FnLow69
FnLow69's Avatar
Re: progress pics
well depending on how low you wanna go, if you wanna lay frame i would install my bag compressed and layed out.
Old 12-22-2006, 03:02 AM   #6
abadsvt
abadsvt's Avatar
Re: progress pics
What i meant is install the bag brackets at ride height. The rear end will rotate a little between dump and ride height and it would be idea to have the bracket level at ride height. That might have been what you meant but just clarifing what i meant. Your truck is looking sweet FNLOW69! I know it is alot of work but isn't it starting to pay off seeing your progress. Keep up the great work!
jlaird- Just curious did you buy a trianglated 4 link or paralle? Talk to you later
Josh
(Project truck)
Old 12-22-2006, 09:37 AM   #7
jlaird
jlaird's Avatar
Re: progress pics
Thanks for the compliments guys. Yes, as you see it in the last pic, the axle is at ride height which was deteremined by the Slam Specialities spec of 5.5"-7" recommended height of their bag(at ride height). Abadsvt, I got the parallel 4-link.
Old 12-22-2006, 02:27 AM   #8
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: progress pics
Project is looking good man! Like Josh said set it all up at ride hieght, This is very important! Trust me i found out the hard way when i did my first back half.....Hate doing work twice....But I learnt from my mistakes...
-Aaron
AesC10s is offline   Reply With Quote
Old 12-22-2006, 12:14 PM   #9
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: progress pics
I was told that your pinion angle should be at the same angle as the transmission but that was after I did mine. I set mine at -4degrees at ride height and it seems to work fine, but I have a one piece driveshaft.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 12-22-2006, 12:32 PM   #10
1lowdiesel
1lowdiesel's Avatar
Re: progress pics
if your running paralle why go over the axle. go with a 6 link design you'll get more lift and a much better ride especially with those slams.
some thing like this
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 12-22-2006, 12:33 PM   #11
1lowdiesel
1lowdiesel's Avatar
Re: progress pics
also you goin w/ a pan hard or a watts link?
xtremediesel.com
Old 12-22-2006, 01:02 PM   #12
1LoC10
Insert Title Here
1LoC10's Avatar
Re: progress pics
lookin good
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 12-22-2006, 02:48 PM   #13
jlaird
jlaird's Avatar
Re: progress pics
I'm going with a panhard bar from Suicide doors. I'm just looking for a simple setup, thats why I'm going over the axle, and I don't need anymore lift than what I'm going to get with my setup.
Old 12-23-2006, 05:49 AM   #14
el curioso
el curioso's Avatar
Re: progress pics
what are the dimensions of your back 1/4 if you don't mind posting. I have these for the one I want to build. Do these more less seem correct or am I way off. It's just that I need to purchase all the tubing before they close for the holidays and before I tare my truck down.(Only source of moving all the tubing with.)
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-23-2006, 06:18 PM   #15
jlaird
jlaird's Avatar
Re: progress pics
El curioso, I took some measurements for you.
Your 34" is 37.75"
Your 30" is 33.75"
Your 20.12" is 24.5"
Your 18" is 10"
Your 12" across the top of the notch is 12"
Your 15" is 12.5"
And your other 12" is 8.5"
Hope that helps.
Josh
Old 04-12-2010, 03:15 AM   #16
jnesto
Re: progress pics
what size square tubing did you use for the c notch?
jnesto is offline   Reply With Quote
Old 12-24-2006, 12:16 AM   #17
el curioso
el curioso's Avatar
Re: progress pics
That really helps. Thank you I'll post pics later on.
Old 12-24-2006, 11:37 AM   #18
tom coop
tom coop's Avatar
Re: progress pics
ive got pretty much the same setup and was wondering where to get a canti setup to eliminate over axle. also whjo makes a good watts link.
tom coop is offline   Reply With Quote
Old 12-24-2006, 11:14 PM   #19
jlaird
jlaird's Avatar
Re: progress pics
I was looking at watts links today. I could only find two company's, kp components which is for later style trucks but I'm sure they can be modded for ours, and totallypolished.com which are for our trucks and looks nicer IMO than the kp. But is is $500 bucks.
http://totallypolished.com/watt's_link_kits.shtml
Old 12-24-2006, 11:31 PM   #20
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: progress pics
Check this one out guys, Its from speedway motors http://www.speedwaymotors.com/xq/asp...qx/Product.htm
-Aaron
Old 01-04-2007, 10:14 AM   #21
XXL
Seņor Member
XXL's Avatar
Re: progress pics
I have one of these units that I played around with, never actually installed on anything, that could use a good home.
XXL is offline   Reply With Quote
Old 12-25-2006, 12:31 AM   #22
1lowdiesel
1lowdiesel's Avatar
Re: progress pics
you could just make your own it's actually pretty simple.
also the canti stuff you could get from ssd but kp components makes bolt on canti and 4 or 6 link kits.
i'm doin my own canti and watts on both my 72 and my diesel. my diesel's already got a reverse 4 link set up, but with 900 lbtq there's a little wheel hop (to say the least). i'm goin with a forward paralle on the outside of the frame. and canti set up w/a bunch of moving parts lol.
xtremediesel.com
Old 12-25-2006, 01:18 AM   #23
steveo10
steveo10's Avatar
Re: progress pics
i made my own watts link but i didn't fine tune it enough so i gave up and bought a panhard. i was going to get one of those totally polished watts links but i didn't feel like spending that much.
Old 12-25-2006, 04:20 PM   #24
Fastlane_Fab
Re: progress pics
On the pinion angle....I have always heard 3-4 degrees down at ride height.
Fastlane_Fab is offline   Reply With Quote
Old 01-01-2007, 10:49 AM   #25
jlaird
jlaird's Avatar
Re: progress pics
Worked on the bridge yesterday...
