registered IWATA user
Suspension work and cutting coils???
since my 71 step is stripped and about to get shaved and primed, i am rebuilding the front suspension, it squeaks worse than anything, what part should i get from the parts store for a complete rebuild, this will be my first time doing this to a truck on my own, since i am not spending al ot of money on my 71 to save for my 72, i am gonna cut the coils to give it a better stance, i know this is crap but i realy dont want to put any more moey than i have to into it. is there something i can measure to tell me if i already have drop springs, he truck came with a 6 stock and now has an 8, i measured to the sidemarkers oneday and i think its 2 inches lower than stock already, how mych do i take off the springs? i want a slight rake, maybe 3 inches in front and 2 in back, thanks, sean
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
In the front I would cut 1/4 of a coil then see where your at. The last thing you want to do is go to low. Dispite the kind words people say about cutting coils, if you cut then grind a flat spot on the coil you cut the ride is exatly the same. I cut mine on my 72 custom and it rides great, after I put spring spacers back in. I lowered mine 4/6 1 coil off front and coil and a half off back. still has about 2 in rake. Now I have a problem dragging the flows over speed bumps. Good luck.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
its all about the +6 inches
One thing to keep in mind, after 2 inches of a drop with just springs, you start running into geomitry problems and bump steer.
so whats a safe, no problems, # of inches to cut? what do i use to cut them, didnt someone say that a torch wil damage them?
