Hot Rods For Life
Anyone have pics of their rear air bag setup?
I am gathering parts together to install my bags on the rear of my truck. It's a coils spring setup so any pics would help.
![]() Join Date: Aug 2006
Re: Anyone have pics of their rear air bag setup?
So are you lookin for ideas or more of how others have theres setup? Here is my setup which is a little different that you might be looking for but I am proud of my setup so i will post it anyways
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#3 | |
Hot Rods For Life
Wow. I am only able to go the basic route now, but that is awesome. I am basicly replacing the coil springs with bags.
#4 | |
tyhink im goin to do something like it
1985 GMC ( future plan pro tour build for the wife ) Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST ![]() ![]() ![]() |
I don't have a pic. I tried to find one because I know 67Fleet posted one of his (mine is the same). I just replaced my coil with the Slam Specialties RE7 bag.
There is the long bolt from the bottom of the trailing arm to the center mounting hole on the bag. Then there is a hole on either side of the center in the top of the arm. Then there are 2 mounting holes in the spring plate and the 1" hole for the fitting. The hardest part is the hole for the fitting. <edit> as well you should be proud of that setup, Josh. It's awesome! I think Zumo is on a budget for his shop rig though. Last edited by jimmydean; 01-23-2007 at 12:25 PM. |
Progress = 0%
With bolt-in c-notch....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Hot Rods For Life
Are you pretty happy with that setup. I plan on a bolt in C-notch as well, but later on. I want to get the bags up and running right now.
#9 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#10 | |
Are you referring to the trailing arm? If so, no. I do have an adjustable panhard bar since my ride height is considerably lower than stock.
If you don't do the notch right now, the axle will be too close to the frame. I used a cup on the top that has a hole in the side for the hose. i will see if i can get a picture tonight.
With the 3" cup, at full dump the axle is resting on the factory bump stop. I will take the cup out once I get the notch installed and I trim my front cup. The cups I used in the rear are the ones with a single bolt. I threaded the bolt and cut it down, it is mounted to the top spring retaining hole. Again, I will try and get a picture so it make sense. [IMG]http://www.*****************/images/products/S10_Single_Port_Bolt_In_Front_Cups.jpg[/IMG] Last edited by jimmydean; 01-23-2007 at 03:26 PM. |
Hot Rods For Life
I have cups also. Thanks Jimmy.
its just $$$$$
heres mine. I built new trailing arms to get a little more drop.
#15 |
Where did you guys get your bags from? I want to order front and back but I want to make sure I order right the first time. Thanks for any info.
'64 c-10 short stepside 400 sb or 402 bb/ th400 rebuild,ongoing project,can of worms. '71 c-20 long fleet for parts '69 c-10 long rolling frame '70 c-20 long fleet work truck |
#16 |
I would get everything from Suicide Doors if you are looking for a basic bag setup. The guys there know what they are doing and the price is the best I've found.
They have a "build your own kit" page that lets you pick everything but the brackets and fittings. |
#17 |
Village Idiot....
Here's mine on my red 68, bags bolted directly to the frame and trailing arm, 2 inch blocks and welded in c-notch......
#18 |
Zumo.... I might be able to help you get a 'budget' rear set-up going if you need some help. Budget means bags, DOT air line, & schrader valves for filling. Cheaper than the full nine yards & effective.
#19 |
Forgive my ignorance on the early style trucks and why you guys do as you do, but based on that picture, it looks as if your axle is just about bottomed out in your notch, and the bag isn't fully compressed. Why not remove that 2" block to allow the bag to compress more and allow yourself to get more lift?
#20 | |
#21 | |
Never Done?
![]() Join Date: May 2000
In effect, your making use of the additional clearance provided by the c-notch all the time, and not just when you're aired out. Last edited by Alvin; 01-28-2007 at 10:03 AM. |
#22 |
Without the block, to acheive a drop equal to 7" requires almost no air pressure in the bag which makes for a 'choppy' ride. By using the blocks for additional drop, you need more air in the bags getting closer to optimal pressures for the best over-all ride.
#23 | ||
#24 |
Thanks jimmydean, I'll check them out.
#25 |
What is the optimal pressue?
