Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-27-2008, 03:53 PM   #1
ronh72c10
Project Git-R-Done - 72 K25
Here's the "official" start of a project I'm calling Git-R-Done, which is a 72 K25 I bought several years ago and am finally doing something with.
The whole objective to to finally complete one project truck, so I'm taking all the parts I've bought for my three projects and going to try and finish this one this year.
It means that the K25 will end up having chevy front end but hey who'll notice.
Basically the truck will be stock, with a 350-TH400-NP205, air, ps, pb, keyless entry and maybe PW, I'll also be building a flatbed for it and am trying to decide if it's worth making it a dump bed.
Here's the before pics as I start disassembly.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 04-28-2008, 11:56 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project Git-R-Done - 72 K25
Looks like a great start, good luck with the build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-29-2008, 12:23 AM   #3
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Looks like a solid start, the old GMC's are great trucks, I just subscribed, keep us posted.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 04-29-2008, 03:22 AM   #4
ronh72c10
I dismantled the old bed today, it's a good thing I decided to build a flatbed for it, the old bed was a disaster, the bedsides were barely worth salvaging.
Next step is to finish disconnecting the cab and pull it and the front clip off in one piece.
Ron
72 GMC 3/4ton 4x4
Old 04-29-2008, 05:45 AM   #5
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Ron
I hear you, mine has never had a bed on it, it has always had some sort of body, I am going to wind up building a custom flat bed for mine and my friends dodge here pretty soon. I need to do my 12 valve Cummins swap first though.
Old 04-29-2008, 05:55 AM   #6
72cheyennesuper20
72cheyennesuper20's Avatar
Cool truck. Cool dogs. Keep up the good work.
72cheyennesuper20 is offline   Reply With Quote
Old 05-17-2008, 04:26 AM   #7
ronh72c10
Well it's been a while since an update on the truck but it's not like I haven't been busy, there have just been alot of things that built up to this point. Now the plan is to blast and prime the K25 frame next week but before I could I had quite a few things to do before I could get to that point, so I'll break them down into a picture series.
Now first off I decided to use the cab I've fixed up for the C10 on the K25, but before I could take it off the C10 frame I had to get it out of the shop, and inorder to do that I had to put the bed back on the frame and before I could get the frame out, I had to fix the brakes on the Studebaker since it was in the way and wasn't safe to move since the brakes were completely gone. One master cylinder and two wheel cylinders later and I could lock the front brakes up.
72 GMC 3/4ton 4x4
Old 05-17-2008, 04:28 AM   #8
ronh72c10
Now unfortunately I've stockpiled alot of scrap metal that needed to be gotten out of the way before I could move the studebaker and C10. Most of the small stuff got dumped in the trunk of the Buick, the rest got dumped on the pile behind the shop.
72 GMC 3/4ton 4x4
Old 05-17-2008, 04:30 AM   #9
ronh72c10
So the studebaker got mobile but before I could start thinking about taking the C10 cab off I needed a place to put the C10 cab until the K25 frame was done since the the K25 cab was going to go on the c10 frame until it was time to fix that cab. So I had to build a cab dolley.
72 GMC 3/4ton 4x4
Old 05-17-2008, 04:32 AM   #10
ronh72c10
Ok so it's time to pull the C10 out of shop, right? Not quite, I had to put the boom back on the tractor.
72 GMC 3/4ton 4x4
Old 05-17-2008, 04:33 AM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Custom boom? Or bought?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-17-2008, 05:11 AM   #12
ronh72c10
One I custom fabricated, pretty simple.
Ron
72 GMC 3/4ton 4x4
Old 05-18-2008, 04:07 AM   #13
ronh72c10
Well I didn't get the cab off, it turns out that the cab and front clip were heavier than the bucket could lift. I'll have to lift the front clip and cab off seperately, so I've taken off all of the bolts holding the clip to the cab, hopefully if the weather isn't too bad tomorrow I'll get it lifted off.
Ron
72 GMC 3/4ton 4x4
Old 05-19-2008, 02:54 AM   #14
ronh72c10
Well I removed the front clip from the K25, removed the cab and put it on the C10 frame, and as well put the k25 front clip on the C10. Moving the cab was a real pain since the tractor simply couldn't lift the complete cab, I ended up having to take the doors off as well as taking the seat out before it was light enough.
Well onto cleaning up the frame.
Ron
72 GMC 3/4ton 4x4
Old 05-19-2008, 02:59 AM   #15
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Now my friend you are at the part where it starts gettin really expensive...
Old 05-21-2008, 01:58 AM   #16
ronh72c10
Well I got to work on the frame today, cleaned all of the old lines off, took the shocks off and removed all of the old exhaust brackets that somebody crappily welded on.
Of course I found some problems, cracks at the very front on the left and right and the typical torch work at the rear.
72 GMC 3/4ton 4x4
Old 05-21-2008, 02:04 AM   #17
ronh72c10
As well I found an enlongated hole on one of the front spring shackles, the tranny crossmember I have is wrong but hopefully useable.
The worst problem is the rear crossmember is badly rusted were it meets the frame, finding a replacement will be really difficult, and repairing it right just as difficult.
Not a real setback but unexpected.
Ron
72 GMC 3/4ton 4x4
Old 05-21-2008, 06:28 AM   #18
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Check out the boss hoss build, I built my own tranny cross member, and it was really easy, not to mention it is now much stronger than the stock stamped job.
Old 05-21-2008, 03:59 PM   #19
ronh72c10
Thanks, I had a quick look and it looks really strong. I'll have to drop by Elmira Steel this week. Maybe I can do the same thing for the rear crossmember as well.
72 GMC 3/4ton 4x4
Old 05-21-2008, 05:47 PM   #20
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I was able to tie in to the bottom side of the frame only, but that is because my truck is a 2wd with a carrier bearing, Eventually I will add supports that go to the upper frame flange. You will definitely want to have them on a 4x4
Old 05-22-2008, 03:03 PM   #21
ronh72c10
Quick update on yesterday's work, pressure washed the frame and tried a little sandblasting with my homemade pressure pot.
It was a little more work than it sounds since it took me 3 hours to get the pressure washer working, next time I'll treat the gas before winter.
72 GMC 3/4ton 4x4
Old 05-23-2008, 04:07 AM   #22
ronh72c10
Todays update, removed the rear crossmember and as you can see it was fairly rusted at the ends, the rest was pretty solid so I decided to save it. I fabbed some patches and tomorrow I'll weld them in.
Ron
72 GMC 3/4ton 4x4
Old 05-26-2008, 04:23 AM   #23
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
it's looking real good man keep up the good work
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 05-28-2008, 12:51 AM   #24
ronh72c10
No update for today, but for yesterday I repaired the top part of the frame at the rear, welded up the cracks on the frame horns and removed the old front crossmember. That means all of the frame repairs are done, sandblasting is next. Unfortunately I didin't get to the point of priming the frame by the end of the week but I'd rather have things done right so the delay was worth it.
72 GMC 3/4ton 4x4
Old 06-03-2008, 08:52 PM   #25
ronh72c10
Wire wheeled the frame on sunday and finished it today. No pics but hopefully this weekend I'll get started on sandblasting. Found out that the wirewheels work really well for cleaning up the diffs as well.
Ron
72 GMC 3/4ton 4x4
