04-30-2008, 05:59 AM | #1 |
SWBs: 67 2x4, 67 4x4, 70 4x4
67 SWB 6 cyl cruiser
I bought this truck off Ebay around November 06.
A nice clean old truck. It was offered by the original owners grandson, who I could tell was hated selling it. Pretty clean over all, the bed had just a little rust from snow not melting, and the rockers were gone. Came with new tires and chains which was nice since I drove it home in a snow storm, the only passenger car on the road, straight thru to Houston, 24 hours. We filled the bed with snow to give it traction. The snow lasted all the way to Dallas before it finally melted. Plans are to keep the 6 cyl, add a 3 spd manual over drive, drop it 5.5" in the front and 5-6" in the rear. Power disc brakes all around, and power steering. Shave the firewall, one piece windows, but keep it clean. I have the truck back from paint now, so this may seem kind of quick.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 Last edited by Conroe trucker; 09-22-2008 at 01:00 PM. Reason: word choice |
04-30-2008, 06:09 AM | #3 |
I have a radical idea!
Re: 67 SWB 6 cyl cruiser
Clean old '67! One day I'm going to have a nice '67 SWB fleet!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-30-2008, 06:10 AM | #4 |
The truck sat in storage for awhile until I finally got ready to work on it.
First was to strip it down. I will spare you the details, but if you need pictures of just about how anything goes together, I probabley have them. I bought another 67 4x4 off Ebay, and the seller threw in a 3 spd OD that was complete, giving me two. I had his rebuilt and we installed it. The 6 was rebuilt completely except for the carb and distributor.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
04-30-2008, 06:20 AM | #5 |
A local body shop that had painted a 55 for me opened up again 3-4 miles down the street. He had a sand blasting pit, and although his pricing was high for body work, his guys were good, and so we struck a deal, or I should say I agreed to his deal
So this group is the frame being blasted and all the parts. If you go easy on it, with not too much preasure, and reuse the sand, you will have no problems. We blasted every panel on the truck, and on these old trucks, there is alot of metal.
04-30-2008, 06:31 AM | #6 |
Since I was not a complete rebuild, which this shop was looking for, I had to wait until there was time to work on my stuff.
This was perfect, because he had no problem letting me do my own work, or helping his guys. It also gave me 2 weeks to have the motor rebuilt and installed, trans rebuilt, install dropped spindles and springs, rebuild the front end, and redrill the rear axles, rebush the trailing arms, install the rear tank, and rerun new brake and fuel lines.
04-30-2008, 06:43 AM | #7 |
Around this pint they started replacing the rockers. We replaced both rockers, athe passenger cab corner, and the tips of the kick panel bottoms. We also welded up all the holes in the panels, gas neck, radio antenae, stake bed pockets, smoothed the firewall, and fabbed the gas cap location.
We also cut the dash for a new DIN style radio slide. Once the body was roughed in thins started happening quick.
04-30-2008, 06:51 AM | #8 |
After everything was primed and ready for wet sanding, we quickly test fit the front end to check alignment. Since I had torn the truck apart before they had seen it, I wanted to make sure we had no problems.
The truck has a nice stance, and maybe could go 1" lower. Once we hang all the sheet metal on it we will look again.
04-30-2008, 06:53 AM | #9 |
wow your really getting after it, its looking really good cant wait to se it all back together
04-30-2008, 06:14 AM | #10 |
sweet, nothing like those inline 6
04-30-2008, 08:11 AM | #11 |
chevy runs deep
Looks good,
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
04-30-2008, 08:22 AM | #12 |
Awesome build, looking forward to the next pictures.
04-30-2008, 08:42 AM | #13 |
Commander Taco Bello
wow, all that work in a day??
great build man. looking forward to the updates |
04-30-2008, 07:10 PM | #14 |
///Relaxed Atmosphere
looks good can wait to see it in person. there area few of us in the houston, tomball, conroe area
jeff
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
04-30-2008, 11:45 PM | #15 |
Thanks for the kind words.
I hope to finish it by the end of summer. Family vacations and heat are going to slow me down. I hope to at least get the cab on, exhaust run, wired, and the steering column in and the shift linkage dialed in by the end of May. If I get that far we will mount the radiator support and spin the motor. I would like to set the valves and timing without the worry of scratching a fender.
05-01-2008, 03:50 AM | #16 |
Tot Roddin'
Wow.... beautiful project! Can't wait to see the end result!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-01-2008, 04:38 AM | #17 |
PROJECT 7DEUCE
Beautiful cant believe how good that sucka looks...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-02-2008, 08:18 PM | #18 |
Love it ! I know I've seen those wheels before what are they ?
keep those pics coming !
"I feel the need for speed!"... as soon as I am done with my nap. |
05-03-2008, 07:44 PM | #19 |
They are RT5s.
They were around $ 250@, 17x8 & 17x9
05-03-2008, 06:14 AM | #20 |
Rusty but Trusty
What are your plans fro heat or air, if any?
Really like the color. It started of as a decent truck, but will be GREAT when your done. I like sixes also. Hoe much HP or torque can the old OD units handle? Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
05-03-2008, 04:43 PM | #21 |
Really turning out nice, truck looks great! I've got a similar 68 I'm working on. Can you tell me what disk brake kit you used? I would like something like you're using on mine. Thanks.
05-03-2008, 08:06 PM | #22 |
I got the cab home early in the week.
We mounted it at the shop, to make things easier. I will roll it out this weekend, clean it up and then add some more pictures. All the panels need to be block wet sanded and buffed out. Maybe we can get that done in the next two weeks. Yesterday we painted the steering column, bed floor, and extra wood floor front panel, the two front inner fenders, and the hood. Today we sprayed the fender and hood undersides with a bed liner called Raptor. It is a hard urethane, not rubbery, that looks and feels like epoxy or fiberglass. It will quiet the wheel wells down, while making them easy to clean, and stiffen the hood to keep it from "oil canning". I picked up a 6 cyl power steering pump and brackets off Ebay, so they need to be taken apart and painted, then mounted also. I have a local chrome plater plating the tin grill trim rings, tin headlight bezels, tin interior door strip, and the one piece aluminum window triangle. Price I was quoted was $ 300, which I felt was good.
05-04-2008, 08:05 PM | #23 |
Looks great!
05-22-2008, 01:45 AM | #24 |
We are finally making progress.
Learned a valuable lesson. New sheet metal is cheaper, much cheaper when you figure body work, but unless you completely install every nut and bolt to fix it first, it will all need modification, and usually after paint. By then end of the week we may have all the metal on it, and then I will get pretty slow knocking out my punch list.
07-29-2008, 09:52 AM | #25 |
I used CPP.
They really screwed up my order, and it took them months to ship everything. No instructions, and the biggest issue was they would not listen on the phone to what I had, even when I told them it was going to be a problem I got the standard, "It will fit". Well, 11" power brakes do not fit with a stock 250 air cleaner, even though I asked before placing the order. And a 67 frame does not have a recess for the PS gear to sit into, it must have a stand off bracket, although I knew from this forum there would be an issue. And the rag joint kit does not need a universal joint to work, and the shipped the kit with out enough copper brake line washers, no mounting brackets for the rear disc brakes, and on and on.
